Add adapters to the control panel
EcoStruxure IT Forum
  • 🔒 Closed
Cory_McDonald
Cory_McDonald Champion
159
Jef
Jef Leader
114
gsterling
gsterling Mentor
77
Back to EcoStruxure IT Forum
DCIM_Support
DCIM_Support Mentor
Mentor
Posted: ‎2020-07-04 05:27 PM . Last Modified: ‎2024-04-04 11:55 PM
1232
Portal is requesting to add adapters to the control panel when trying to connect Expert to Portal. How can I resolve this issue?
(CID:131958962)
  • Portal
DCIM_Support
DCIM_Support Mentor
Mentor
Hi Arnold,
Seems to be basically a configuration issue, eg. you would need to connect the portal to DCE. Here is how to:
From the top menu select Go to > Control Panel:
and then in Portal > Connect to StruxureWare System, click on Add StruxureWare System:
in the Connect to StruxureWare System page, select "StruxureWare Data Center Expert" as Service provider (from the drop down list):
enter the configuration settings,, and save.
Now you should be able to portlet/alarms, etc.
Hope this helps,
Kind regards
(CID:131962040)
Replies 4
DCIM_Support
DCIM_Support Mentor
Mentor
Dear Arnold Auzenne,
Please show a screenshot of this issue. And then you will be helped here faster and better 😀.
With respect.
(CID:131961156)
DCIM_Support
DCIM_Support Mentor
Mentor
Here is the screen shot. This only occurs when I try to add the alarms to portal.
(CID:131962033)
DCIM_Support
DCIM_Support Mentor
Mentor
Hi Arnold,
Hope this helps,
Kind regards
(CID:131962040)
DCIM_Support
DCIM_Support Mentor
Mentor
Posted: ‎2020-07-04 05:27 PM . Last Modified: ‎2023-10-20 04:58 AM
