Continue
  • My Subscriptions
  • Events
Add Eaton ATS16 to Export
  • Add Eaton ATS16 to Export
Cory_McDonald Champion
160
Jef Leader
114
gsterling Mentor
79
DCIM_Support Mentor
Mentor
Posted: ‎2020-07-05 06:27 PM . Last Modified: ‎2024-04-03 02:59 AM
1886
Hello
I have added the all Eaton’s ddf (from this site)  files to export . Unfortunately after discovery in  into “View Device Sensors..” I see only “Link Status” and “Network Interface Status” . It’s like I did see before uploaded the ddf files .
I don’t see any sensors that device has .
(CID:141267729)
  • DDF
DCIM_Support Mentor
Mentor
1885
Hi Boris,
If you can't find what you need, click the "Request" button, and let us know what you need.  If you can include a walk file from the device along with that request, that would make it much easier for us to locate the best matching DDF.
Jake
(CID:141267872)
Replies 7
DCIM_Support Mentor
Mentor
1885
Hi Boris,
Jake
(CID:141267872)
DCIM_Support Mentor
Mentor
Hello
First off all many thanks on answers .
I have downloaded and import the ddf files of the DCE all the following files from ddf search :
(CID:141268246)
DCIM_Support Mentor
Mentor
Dear Boris,
First, it is not recommended to import a large number of DDF-files for all occasions into the DCE-server. It is very correct to keep on the DCE-server only those DDF-files, that are really necessary for your specific equipment.
Secondly, if the equipment is not yet supported by DCE software, then you need to make the appropriate device support request, as Jake Hiltz wrote, that is:
Try it and DDF team will help you.
With respect.
(CID:141268263)
DCIM_Support Mentor
Mentor
Dear Boris,
From your question:
Please, specify the names and versions of these DDF-files.
As stated in the similar topic :
Unfortunately, according to the Device Support resource, the DCE software does not yet support the above equipment.
Therefore, Jake Hiltz is right, you need to make the appropriate device support request.
With respect.
(CID:141268174)
DCIM_Support Mentor
Mentor
If I understand correct the Eaton ATS16 don't support on DCE .
How I can set monitoring in other way .
(CID:141268986)
DCIM_Support Mentor
Mentor
Dear Boris,
Tell us, please, did you solve your question or not?
With respect.
(CID:141269173)
DCIM_Support Mentor
Mentor
Posted: ‎2020-07-05 06:27 PM . Last Modified: ‎2023-10-20 04:58 AM
