Accessing Netbotz 755 with REST API
Select a Country
  • Accessing Netbotz 755 with REST API
Cory_McDonald Champion
159
Jef Leader
114
gsterling Mentor
77
n_nagra
n_nagra
Explorer
Posted: ‎2025-11-11 08:31 AM
2
752
I am trying to access the netbotz api with python script. I am keep getting 403 Forbidden error or 400 client error even after passing credentials for authorization. However, the url works fine in browser after logging to the device, Could anyone please share their experience on how to access the api?
  • NetBotz
Champion
Posted: ‎2025-11-14 09:23 AM
Hello @n_nagra,  The NetBotz 750/755 RestAPI Login uses sessions with cookies for authentication.  I have attached a python file (extension is a .txt to be able to post for security reasons) that will hopefully help you understand the authentication mechanism through the use of the the cookies.
You will need to do the following:
- Edit line 211 and add the IPv4 address of the NetBotz Appliance
- Edit line 214 and add the password for the NetBotz Appliance
- Create a python 3.13 environment with the following python dependences
     - requests==2.32.4
- This is usually accomplished by running "pip install requests" in a Python workspace
The file shows how to log into a NetBotz 750/755 appliance using Python.  The function that does this is called nb_login.  The NetBotz RestAPI authentication mechanism uses Cookies so you will want to pay special attention to:
        returnMap['JSESSIONID']  = response.cookies.get('JSESSIONID')
        returnMap['XSRF-TOKEN']  = response.cookies.get('XSRF-TOKEN')
The dict returned by the nb_login method contains cookies.  The nb_get method shows how those are added to subsequent request.
Cory
nb_example.py.txt
Champion
     - requests==2.32.4
Cory
nb_example.py.txt
n_nagra
n_nagra
Explorer
Posted: ‎2025-11-14 09:32 AM
Thank you for your help.
