Access Portal via HTTPS 443 Connection vs 8080
Select a Country
  • Access Portal via HTTPS 443 Connection vs 8080
Cory_McDonald Champion
159
Jef Leader
114
gsterling Mentor
77
DCIM_Support Mentor
Mentor
Posted: ‎2020-07-04 05:52 PM . Last Modified: ‎2024-04-04 11:46 PM
1907
For security reasons, we want to access the Portal server using https port 443 instead of the current port 8080, can this done configured?
(CID:131962953)
  • Portal
  • security
Replies 4
DCIM_Support Mentor
Mentor
Dear Lai Yuan Jiun,
You can find the answer to your question, for example, in a similar my topic :
By default, https is on port 8443.
If you need to disable http, then edit the "server.xml" file and un-comment (use "") the connection via HTTP / port 8080.
And for the https configuration, see the following guide:
http://liferaysatish.blogspot.se/2012/06/ssl-with-liferay-tomcathttp-to-https-on.html
I hope this is what you need.
With respect.
(CID:131962973)
DCIM_Support Mentor
Mentor
Dear Lai Yuan Jiun,
Have you been able to solve your problem or not?
With respect.
(CID:131966493)
DCIM_Support Mentor
Mentor
We are still working on it, will update soon, thanks.
(CID:131967000)
DCIM_Support Mentor
Mentor
Posted: ‎2020-07-04 05:52 PM . Last Modified: ‎2023-10-20 04:58 AM
