Continue
  • My Subscriptions
  • Events
VBSscript changes in Geo SCADA 2025R2 new script engine
  • Remote Operations
  • VBSscript changes in Geo SCADA 2025R2 new script engine
sbeadle
sbeadle Champion
337
AndrewScott
AndrewScott
128
BevanWeiss
BevanWeiss
104
  • Remote Operations Forum
EcoStruxure™ Geo SCADA Expert
rlao
rlao
Contributor
Posted: ‎2026-10-27 10:56 PM
4
421
With the recent release of 2025R2, the Geo SCADA Knowledge Base has been updated with a new article, which outlines all the changes to VBScript as part of the new script engine introduced in 2025R2.
Are these changes being presented as known bugs to be actioned or intended features that are here to stay? A lot of them are changes to what has been previously considered valid syntax for years, such as the use of default properties on Forms (no longer supported in 2025R2) and not needing to populate all pick action parameters to execute a script (2025R2 now needs everything to be explicitly populated). Updating our mimic scripts to conform to these new rules is a monumental effort for us with the size of our SCADA systems.
And to be frank, some of these announced changes sound a bit bizarre. List Boxes now scroll horizontally rather than vertically when you populate them with more items that graphically fit into the box? Does this mean we can no longer design our forms to have vertical scroll bars on list boxes? Again, is this being presented as a bug or a feature?
As an end-user, I am very concerned about the amount of work we need to do to prep our systems for the 2025R2 update. We definitely weren't expecting to have to overhaul our scripting just to be able to move to this update. I have already raised a few of these with Support who have pointed me back to this very same KB article, so it feels we are going a bit in circles.
  • SCADA
  • Scripting
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
Replies 4
AdamWoodlandToo
AdamWoodlandToo
Mentor
Posted: ‎2026-10-28 05:17 PM . Last Modified: ‎2026-10-28 05:34 PM
In a bit of self-promotion, these issues have driven (not supported or sanctioned by SE, open-source and provided without warranty) https://github.com/adamwoodland2/GeoSCADA-Script-Exporter which does two things:
1. Exports the scripts from mimics, pick actions and script libraries to disk (needs access to a running Geo SCADA, have tested it against 2025 R2 Release only)
2. Analyses the exported files (no access to Geo SCADA needed so you can copy files off a server) and identifies the issues highlighted in the article above.
As things get found or new thing get added to the article, the analyser script gets updated (using Claude).
People are welcome to give it a go against a test database and see if it is of any help.
sbeadle
sbeadle Champion
Champion
Posted: ‎2026-10-29 03:17 AM
371
A big thank-you to Adam for creating this tool.
Unfortunately the script engine has had to be changed because Microsoft is eventually withdrawing VBScript. You'll see evidence of this in the Windows Event Viewer when ViewX is started - warnings for applications using VBScript.
The script engine has transitioned to .Net, and some changes were needed because the new engine has some different behaviors. .Net and WPF forced list scrolling to change, and the script engine is more 'fussy' about types etc.
Support and development will be keeping a close eye on feedback and tickets, so some issues could be investigated to see if there are ways to improve them. (e.g. the missing parameter issue).
Further feedback is welcome.
rlao
rlao
Contributor
Posted: ‎2026-10-29 05:09 PM . Last Modified: ‎2026-10-29 05:15 PM
In response to sbeadle
Hi Steve,
Thanks for the info
Regarding the general tightening of syntax, I don't believe the full impact of this script engine change has been accurately communicated in Schneider's messaging, hence why it has caught us off-guard.
The GS2025R2 release was recently presented at one of the Schneider roadshows I attended. The question was asked about the new scripting changes and the feedback from the presenters was that they were not aware of any major impact to existing scripting...
This has not been the case for us at all. Even with templating and use of script libraries, all these 'minor changes' are replicated hundreds (possibly thousands) of times across all our scripts. Sifting through and fixing them all up is very time-consuming if we don't homebrew our tools like what Adam has (thanks to Adam for sharing these as well). Are Schneider going to be developing tools to help end-users navigate these changes?
On specific changes:
The Pick Action change is going to catch a lot of people out, because it will silently fail if you don't specify all arguments now. I think we need to have a proper error message now if this method of configuration is not allowed.
Is vertical scrolling on List Boxes truly gone? We have widely used user forms that generates long lists of points for users to multi-select to build ad-hoc trends. Having those be horizontally scrollable makes the form look extremely weird and not a pleasant user experience at all. And there is nothing we can do to work around this as an end-user.
sbeadle
sbeadle Champion
Champion
Posted: ‎2026-10-30 04:02 AM
Thank you very much for this feedback. They will reassess the specific items of pick actions and scrolling.
