Query to show tags that is an instance of a template
Select a Country
  • Remote Operations
  • Query to show tags that is an instance of a template
sbeadle
sbeadle Champion
337
AndrewScott
AndrewScott
128
BevanWeiss
BevanWeiss
104
  • Remote Operations Forum
EcoStruxure™ Geo SCADA Expert
Clearscada_EIT
Clearscada_EIT
Explorer
Posted: ‎2026-08-06 01:19 PM
348
I have a list of all the tags inside my database, my task is to query create a query to show all the tags that are instance of a template and tags that don't belong to any template
Does anyone has a query can do this task?
  • SCADA
  • ViewX
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
AndrewScott
AndrewScott
Leader
Posted: ‎2026-08-11 02:01 AM . Last Modified: ‎2026-08-28 09:37 AM
The CDBObject::ParentTemplateId field will give the object ID of the template that controls the object or NULL_REFID (minus one) if it is not controlled by a template.
The following query will give the local objects in an instance that are not controlled by a template, where <Instance Group Full Name> is full name of instance that you want to query:
SELECT Id, FullName FROM CDBObject WHERE ParentTemplateId = -1 AND FullName LIKE '<Instance Group Full Name>.%'
 NB. There is trailing dot and percent (wildcard) on the end of the instance name so that only objects in the group are queried.
Andrew Scott, R&D Principal Technologist, AVEVA
Replies 6
AndrewScott
AndrewScott
Leader
Posted: ‎2026-08-07 01:36 AM
339
The CDBObject::ParentInstanceId field will give the object ID of the template instance that the object is in or NULL_REFID (minus one) if it is not in a template instance.
SELECT Id, FullName FROM CDBObject WHERE ParentInstanceId <> -1
Clearscada_EIT
Clearscada_EIT
Explorer
Posted: ‎2026-08-07 07:50 AM
In response to AndrewScott
Thanks Scott,
The problem I have is within the same Instance folder, I have some tags that come from the template and some one off tags too, the query above will list all the tags under a folder of template instance but doesn't tell you if the tags are from the template or one off tag
AndrewScott
AndrewScott
Leader
sbeadle
sbeadle Champion
Champion
Posted: ‎2026-08-18 05:46 AM
This page shows how to use Python to get template/instance heirarchy information:
https://community.se.com/t5/Geo-SCADA-Knowledge-Base/Python-API-Reading-the-Instance-and-Template-St...
Clearscada_EIT
Clearscada_EIT
Explorer
Posted: ‎2026-08-26 11:16 AM
Hi Steve,
I replicated the example in the link that you shared and use this query
SELECT WITH TEMPLATES
	"Id", "Id", "FullName", "TypeDesc", "ParentInstanceId", "ParentTemplateId", "ParentInstanceId"->"TemplateId", "ParentInstanceId"->"TemplateId", "ParentInstanceId"->"TemplateId"->"FullName"
FROM	CDBOBJECT
WHERE	"FullName" LIKE 'test.%'
ORDER BY "FullName" ASC
as you can see, the result of the query doesn't tell you if a point comes from a template (with the red arrow). Or it's Freestanding point. So for now, I can no idea how to distinguish between a point from a template of Freestanding points
We are still using Geoscada 2023 so no Python application.
sbeadle
sbeadle Champion
Champion
Posted: ‎2026-08-28 01:59 AM
Hi. You CAN use Python with Geo SCADA 2023, either on the same host or a different host.
Just install Geo SCADA 2025+ on any other PC and get hold of the files in the PythonPackages folder:
C:\Program Files\Schneider Electric\ClearSCADA\PythonPackages
Then copy these to the PC where you're going to run Python and call the PIP command, e.g:
python -m pip install --force-reinstall --no-index --find-links="C:\Program Files\Schneider Electric\ClearSCADA\PythonPackages" geoscada-client
(Future note for Geo SCADA 2025 R2/88 versions - also find the Python packages when you install just the Client installer at: C:\Program Files\Schneider Electric\ClearSCADA Client\PythonPackages).
