Posted: 2026-10-15 12:37 AM
In most of the examples and training materials related to GeoScada ,I can see faceplates been designed as local mimics in which the mapping to the tag parameters is direct . But in most of SCADA applications customers dont easily agree for multiple instances when there is option for global symbols and faceplates.
In my case I have created a generic symbol being used with all analog types and a generic popup as per requirement, Now I tried passing tag parameters to the faceplate by adding new parent group and child parameters in parameter tab of the symbol. But it is not getting linked with the parameters in the faceplate.
Is there any other method for linking parameters to next hierarchy like we add in Archestra screens for passing parameters
Posted: 2026-10-19 01:20 AM
The best and simplest way is to embed the faceplate into the site/thing template. Yes, there will be a copy per site/thing, but the overhead is minor. This way you get the relative referencing and everything is easy.
An alternative is have a standalone mimic for the faceplate and to pass the full names of object(s) as parameters. Then use indirect expressions like ["parameter:FullName1"+'.CurrentValue']
This method is a bit fiddly, and indirect animations carry a 'refresh cost' which is higher load on server and client.
Posted: 2026-10-21 12:03 AM . Last Modified: 2026-10-21 04:30 AM
Thanks Steave. I tried the alternate method to pass the Full name. But somewhere I am getting issues in passing the parameter to the hyperlinked faceplate. I doubt the scenario of creating parameters in symbol with a group name and trying to create parameters in Faceplate with another group name is restricting them getting linked.
If we try to autoconfigure the symbol with a tag , do we have a chance for passing the same into faceplate as well?
Posted: 2026-10-26 12:33 AM
Hi Steve,
I managed to pass tagname and replicated all the related details in faceplate. But during the passing from symbol to faceplate through the hyperlink , I am not able to transfer any variable/dynamic values and rather only text is getting assigned to next level. Is there any way (or syntax) in which we can transfer dynamic values to next level so that the same template can be used for all tags.
