Posted: 2026-05-29 07:22 AM
I found inconsistent behavior in Geo SCADA Expert 2023 (2025) with an OPC UA Digital Output point. OPC UA digital output points are controlled through the standard Control mechanism when configured as output points.
Control for output points uses a Value field in the dialog.Action = 1 in the Mimic Method Pick Action, it fails with:The call to the method 'Control.Control' included the following unexpected argument(s): Value. The Mimic Method Pick Action is supposed to support predefined values where applicable.Control.Control(0) or Control.Control(1), it works correctly. Method Calls store arguments in configuration and execute them via Execute.
So this seems to be a Mimic Method Pick Action issue, not an OPC UA write issue. The same method works through Method Call, but not directly from the Mimic when the argument is fixed.
Has anyone seen this before?
Is this a known limitation/bug in Geo SCADA Expert 2023 (2025) for OPC UA Digital Points?
Posted: 2026-05-29 10:29 AM
This issue is described in the known issues list: Releases - Known Issues
