Continue
  • My Subscriptions
  • Events
Creating a Dynamic/Configurable Trend View on Mimics (Runtime Customization)
  • Remote Operations
  • Creating a Dynamic/Configurable Trend View on Mimics (Runtime Customization)
sbeadle
sbeadle Champion
337
AndrewScott
AndrewScott
128
BevanWeiss
BevanWeiss
104
  • Remote Operations Forum
EcoStruxure™ Geo SCADA Expert
abdullah123456789
abdullah123456789
Explorer
Posted: ‎2026-03-24 11:00 PM
796
I am using Geo SCADA Expert 2023 (November 2024 release). I want to design a configurable Trend interface on my Mimics that operators can easily customize during runtime. My goal is to have a list of signals (via a ComboBox or a ListBox) next to or below the Trend object. I want to be able to drag and drop these signals onto the Trend or use a practical selection method to add them to the view. For instance, if I have 5 signals available, I might want to display only 2 of them at a time, then easily add others or remove existing ones as needed. Essentially, I want the Trend object to be fully adjustable by the user without entering Design Mode. What is the best way to achieve this dynamic functionality during runtime? How should I approach this, and what methods would you recommend to make this as seamless as possible?
Thanks in advance for your suggestions!
  • SCADA
  • ViewX
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
AdamWoodlandToo
AdamWoodlandToo
Mentor
Posted: ‎2026-03-25 04:45 PM
I have seen some customers do this using mimic scripting and the trendspec functionality. Basically create a VBScript form with the content you need, allow the user to select the properties, then with the resultant info pass it to the trendspec function (see https://tprojects.schneider-electric.com/geoscadahelp/geo%20scada%202019/Default.htm#TrendsGuide/Usi... or check your help)
Does mean recreating the trend each time a trace is to be added or removed.
AdamWoodlandToo
AdamWoodlandToo
Mentor
sbeadle
sbeadle Champion
Champion
Posted: ‎2026-03-26 02:51 AM
Please do note that the Trendspec trend will be a window (tab or floating).
sbeadle
sbeadle Champion
Champion
Posted: ‎2026-04-23 08:52 AM
Note that Help has moved - that page is now at:
https://product-help.schneider-electric.com/RemoteOperations/Geo%20SCADA%20Expert%202025/Default.htm
