Thread safe methods in Experior
Digital Twin
This knowledge base is addressing usage of software Experior, Machine Expert Twin and future Automation Expert Twin. These softwares are used to create smaller instances of digital twins for use in industrial automation, warehouse management, design & engineering with more..
Select a Country
  • Digital Twin
  • Thread safe methods in Experior
  • Kasper.Vestrup
    Kasper.Vestrup
Back to Digital Twin
Kasper.Vestrup Explorer
‎2026-01-15 05:34 AM
on ‎2026-01-15 05:34 AM
To safely change properties and call methods in Experior be sure that you are running in the “Engine thread”. If the Property Experior.Core.Environment.InvokeRequried is false, then you are running in the “Engine thread”. Otherwise you need to invoke the method call.
Example code:
private void SomeMethod()
    if (Experior.Core.Environment.InvokeRequired)
        //Not running in Experior Engine thread
        Experior.Core.Environment.Invoke(SomeMethod);
        return;
    //Put method code here.
    //Code is executed in Experior engine thread
    //and it is safe to call Experior methods.
Labels (2)
  • Exp-6 Developer Guide
  • Experior 6
