Setting up URSim with Experior 6
Digital Twin
This knowledge base is addressing usage of software Experior, Machine Expert Twin and future Automation Expert Twin. These softwares are used to create smaller instances of digital twins for use in industrial automation, warehouse management, design & engineering with more..
Send InviteCancel
3. Open VMware Workstation. Open the URSim virtual machine (Player-File-Open, then browse the file explorer to where you unpacked the files from 2.a., then select the .vmx file).
4. When the virtual machine is running, open the file with the name of the robot that you want to simulate. Then, turn the virtual robot on using the button on the bottom left.
Then click ON and START.
5. Open Experior 6.0. Make sure the UniversalRobots catalog is selected in the catalog selector. Drag and drop the desired robot from the Catalogs panel to the model.
6. Go to URSim and open the robot settings.
In the settings menu, select System-Network. Note the URSim IP address.
7. Connect URSim to Experior. Do this by going to your Experior model, selecting the robot, and writing the URSim IP address in the IP Address field, under Robot connection.
7.1 Afterward, right-click on the robot and select Connect to robot controller. After this, the robot in Experior will snap into the position of the robot in URSim.
After this, the robot in Experior will replicate the trajectory of the robot in URSim.
Connecting robot I/O through Modbus TCP
The following steps show how to connect the robot I/O through the URSim Modbus server and the Experior Modbus client.
1. In URSim, go to Installation- Fieldbus- Modbus- Add a new signal. (Initially, the variable list will be empty) In the dropdown menu, select the variable type: Digital Input/Output, Register (byte) Input/Output. Rename the variable (this is the name that will be used in the UR programming interface)
2. Assign the memory address for the variable. For this, you need to take into account that all the addresses have specific uses (see here).
3. In Experior, add the Modbus client by right-clicking the Communication panel, and selecting Modbus.
4. Select the Modbus client, and in the Properties panel, write the URSim IP address in the IP Address field, under Communication.
5. Assign Input/Output variables to the desired components. To do this, first set the Connection id to the id corresponding to the Modbus client. Then, assign the memory address of the Modbus server (assigned in step 2) in the Address field for the specific Input/Output. Modify the Register value, depending on the variable type defined in step 2. For Register Inputs/Outputs, Modify the Size value to UInt16 (WORD).
6. After all the memory addresses have been set in Experior, right-click on the Modbus client and click connect. While the connection is active, you won´t be able to modify the associated I/O in Experior.
After this, the variable values will be represented in the Experior model.
(This example was made with the Display assembly, found in the Advanced catalog)
