Logging and Diagnostic messages
Digital Twin
This knowledge base is addressing usage of software Experior, Machine Expert Twin and future Automation Expert Twin. These softwares are used to create smaller instances of digital twins for use in industrial automation, warehouse management, design & engineering with more..
Send InviteCancel
Will be shown as follows (when no filter is applied);
Debug log
Similar to the regular logging there is also the possibility to only log your message in case the debugging option is set in Experior.
In this case the Experior.Core.Environment.Log.Debug class is used with the public static void Write(string message) method.
Example:
Experior.Core.Environment.Log.Debug.Write("This is an example debug message");
Diagnostic info
Experior also provides the possibility to print diagnostic messages to other areas than the logging window.
Therefore the class Experior.Core.Environment.Diagnostic contains the following static methods:
public static void Message(string message);
public static void Message(string message, Color color);
public static void Message(string sender, string message);
public static void Message(string message, Color color, Environment.DiagnosticAction action);
public static void Message(string sender, string message, Color color);
public static void Message(string message, Color color, Environment.DiagnosticAction action, Environment.Signs sign);
public static void Message(string sender, string message, Color color, Environment.DiagnosticAction action);
By default the messages are shown in the status area underneath the working area.
The arguments are:
Message: The information that will be shown.
Sender: This string appended with a : will be shown before the message. It is mainly used to provide the origin of the message e.g. the Assembly name.
Environment.DiagnosticAction: This is an enum with the following possible values; ALARM in this case the message will also be shown in the alarm window of experior TEMPORARY in this case the message will only be shown for couple of seconds TEMPORARYANDLOG in this case the message will only be shown for couple of seconds but it will also be printed to the log window (where it will remain) STICKY in this case the message will remain visible in the status area until a new message is requested or until the message is removed or the Clear() method is called of the Diagnostic class REMOVE way to remove a STICKY diagnostic message NONE
Environment.Signs: This is an enum to indicate what icon should be attached to the message in the status area.
