Internal communication
Digital Twin
This knowledge base is addressing usage of software Experior, Machine Expert Twin and future Automation Expert Twin. These softwares are used to create smaller instances of digital twins for use in industrial automation, warehouse management, design & engineering with more..
Select a Country
  • Digital Twin
  • Internal communication
  • Kasper.Vestrup
    Kasper.Vestrup
Back to Digital Twin
Kasper.Vestrup Explorer
‎2026-01-15 05:37 AM
on ‎2026-01-15 05:37 AM
Experior provides an infrastructure for sending messages between objects.
In the Developer samples catalog an example of how to do this can be found.
The basic steps are;
  1. Register an object as a listener.
Core.Communication.Internal.AddListener(object listener, RecieveMessage method)
For example.
Core.Communication.Internal.AddListener(this, ReceiveMethod);
Where a method like this should be provided.
void ReceiveMethod(object sender, object reciever, object message, bool broadcast)
2. Send a message to a known receiver.
Core.Communication.Internal.SendMessage(object sender, object reciever, object message)
Broadcast a message to all listeners.
Core.Communication.Internal.BroadcastMessage(object sender, object message)
Broadcast a message to all listeners of a specific type.
Core.Communication.Internal.BroadcastMessage(object sender, Type recieverType, object message)
Broadcast a message to all listeners of a specific type (FullName).
Core.Communication.Internal.BroadcastMessage(object sender, string recieverTypeFullName, object message)
3. When an object should stop listen or is disposed it should be removed.
Core.Communication.Internal.RemoveListener(object listener)
Note: The specified delegate of the reciever is executed synchronously.
Labels (2)
  • Exp-6 Developer Guide
  • Experior 6
