Dynamic Properties
Digital Twin
This knowledge base is addressing usage of software Experior, Machine Expert Twin and future Automation Expert Twin. These softwares are used to create smaller instances of digital twins for use in industrial automation, warehouse management, design & engineering with more..
Select a Country
  • Digital Twin
  • Dynamic Properties
  • Kasper.Vestrup
    Kasper.Vestrup
Back to Digital Twin
Dynamic Properties
Kasper.Vestrup Explorer
‎2026-01-15 05:36 AM
on ‎2026-01-15 05:36 AM
You can add properties to assemblies at runtime.
To enable the feature the class has to use the attribute Experior.Core.Properties.DynamicObjectConverter.
Example:
Adding properties two properties
Properties.Add(newDynamicProperty { Name = "Value1", Type = typeof(int), Description = "custom property (integer)",Category = "Testing", Value = 1 });
Properties.Add(newDynamicProperty { Name = "Value2", Type = typeof(float), Description = "custom property (float)", Category = "Testing", Value = 10.0f });
By overriding the DynamicPropertyChanged method the object can handle the changes made to the properties added above
public override void DynamicPropertyChanged(DynamicProperty property)
    Log.Write(property.Name + " is changed to " + property.Value);
See the sample DynamicProperties class in the Demo catalog for more information
Labels (2)
  • Exp-6 Developer Guide
  • Experior 6
