Building a model in discrete events mode
Digital Twin
This knowledge base is addressing usage of software Experior, Machine Expert Twin and future Automation Expert Twin. These softwares are used to create smaller instances of digital twins for use in industrial automation, warehouse management, design & engineering with more..
Send InviteCancel
Adjust the length of the straight by either clicking and dragging from one of the endpoints or by selecting the straight and in the Properties window scroll down and adjust the value in the Length field
As a note, tracks, by default, run from the red point to the blue point, so when attaching additional items opposite coloured points must be snapped together to ensure the model flows correctly
Add the rest of the components, re-sizing as necessary
To join the components together move them together so the the blue and red connection points merge, while holding down CTRL to snap the two components together
To merge components to make diverters, simply drag one component over the other until both highlight, then hold the CTRL key to snap them together
To add an Action point right click on the component on which you want the Action point and selecting Insert Action point and then click Action point
The Action point is represented by an X, initially in the center of the track
The Action point can be moved and modified by selecting it and editing the properties
The ones needing to be changed as part of this exercise are outlined
You can add more than one Action point to a component
Use the Distance property to ensure they are spaced apart correctly
It is recommended to add them and position them one at a time so they don’t end up on top of each other
Add a feeder to the first straight, by selecting the straight, right clicking and selecting Insert Feeder
The properties for the Feeder should be as below
As with the Action point, the properties that need changing are outlined in red
Once the model is built and all action points are added and named as in the initial picture, click the Routes tab and it should look like the one below
Creating the Controller
Within Experior a simple controller can be programmed to dictate the actions of loads when they reach certain action points on the route
The code has been included below in its entirety with comments to provide guidance in what the code is actually doing
First, open the controller tab in Experior. It’s located on the same pane as the Model Construction area.
Copy the code below and paste it into the Controller pane so that it overwrites the default lines already present
public class Main
//This line is autogenerated as part of the model.
public void Arrived(INode node, Load load)
//If the Actionpoint is named CHECK then
if (node.Name == “CHECK”)
//Generate a random number from 1 to 5 & if the number equals 3…
if (Experior.Core.Environment.Random.Next(1, 5) == 3)
//…move the load to Actionpoint REJECT1…
load.MoveTo(“REJECT1”);
else
//…if the number is not equal to 3 move the load to Actionpoint ROUTE1
load.MoveTo(“ROUTE1”);
//If the Actionpoint is named REJECT1 then…
if (node.Name == “REJECT1”)
//…remove the load from the model/system
load.Dispose();
//If the Actionpoint is named ROUTE1 then…
if (node.Name == “ROUTE1”)
//…move the load to Actionpoint INSPECT1…
load.MoveTo(“INSPECT1”);
else
//…if the number is not equal to 3 move the load to Actionpoint INSPECT2
load.MoveTo(“INSPECT2”);
//If the Actionpoint is named INSPECT1 then…
if (node.Name == “INSPECT1”)
//…move the load to Actionpoint ROUTE2
load.MoveTo(“ROUTE2”);
//If the Actionpoint is named INSPECT2 then…
if (node.Name == “INSPECT2”)
//If the Actionpoint is named ROUTE2 then…
if (node.Name == “ROUTE2”)
//…move the load to Actionpoint REJECT2…
load.MoveTo(“REJECT2”);
else
//…if the number is not equal to 3 move the load to Actionpoint PACK
load.MoveTo(“PACK”);
//If the Actionpoint is named REJECT2 then…
if (node.Name == “REJECT2”)
load.Dispose();
//If the Actionpoint is named PACK then…
if (node.Name == “PACK”)
load.Dispose();
What the code basically does is randomly determine where loads should go if the Action point has more than one destination
More advanced controllers can be scripted using Visual Studio. This topic is covered here: Build a Controller
When the code has been entered into Experior, press the Compile button to compile the script
Now when the model runs loads, it will act according to the Controller code
Running the Simulation
Introduce loads to the system by selecting the feeder and pressing the Space bar
Next, under the Model menu, press the Running Man button so that it turns blue
