Adding an OPC Server and Symbols
Digital Twin
This knowledge base is addressing usage of software Experior, Machine Expert Twin and future Automation Expert Twin. These softwares are used to create smaller instances of digital twins for use in industrial automation, warehouse management, design & engineering with more..
Send InviteCancel
As an alternative to using Fetch/Write, an OPC Server can also be used to test a model. This guide shows how to use an OPC Server to program and run the basic psychics model example.
KEPServerEX from Kepware and its predefined variables will be used for this example.
The server should be running on the PC before this exercise is attempted.
First, click on the Communications tab on the right of the Experior window, just below where the Catalogs are displayed
Now right click on the first line and select OPC
Select the newly created OPC Server and in the Properties panel edit it like so
If something other than Kepware is being used than that will appear in the dropdown instead
The symbols and associated items are listed in the table below
INPUTS
Boolean1 Motor Control “Switch”
Boolean2 Feed Load “Button” & Feed Load “Sensor” (2nd Sensor in system)
Boolean3 Load In System “Sensor” (1st Sensor in system)
OUTPUTS
Boolean1 Motor Drive Control
Boolean2 Feeder “Feed Load” Control
Boolean3 Load In System “Lamp”
Select the switch called Motor Control in the Control Panel
In the Properties panel, below PLC Input expand the section by clicking the arrow to the left of where it says On/Off
In the Symbol field click the drop down button
The structure of the OPC Server then appears as a drop down enabling the user to scroll through and select the correct symbols
For this example the Booleans under K Registers is used
Expand the folder that contains the symbols
Select the symbol Boolean1 to have it added to the properties of the item
Now select the push button Feed Load
In the Properties scroll down to PLC Input and expand the section by clicking the arrow to the left of where it says Pushed
Select the symbol Boolean2 to have it added to the properties of the item
Now select the second sensor that was added to the model
In the Properties scroll down to PLC Input and expand the section by clicking the arrow to the left of where it says Blocked
Now select the first sensor that was added to the model
Select the symbol Boolean3 to have it added to the properties of the item
Select the Motor by clicking any of the red arrows in the model
In the Properties scroll down to where it says Operations and expand the section for Forward (Output) by clicking on the arrow to the left of it
Now select the Feeder, that is the triangle/arrow located on the first straight that was added to the model
Scroll down the Properties to the section PLC Output and expand the section for Feed by clicking on the arrow to the left of it
Lastly select the Lamp in the Control Panel
In the Properties scroll down to PLC Output and expand the section under Lighting by clicking the arrow to the left of it
When finished the Inputs and Outputs tabs should look like so
