CPG Expert Forum DACH
News, Tipps & Tricks sowie KnowHow Austausch zwischen Experten und Anwendern rund um die Automatisierungslösungen - speziell PacDrive - im Segment Consumer Packaged Goods.
Posted: 2022-11-15 11:36 PM
Die Ports in folgender Liste werden vom PacDrive3-System verwendet:
List of port numbers
Port number |
Service |
Description |
20 |
FTP |
File transfer (from server to client) |
21 |
FTP |
File transfer (initiating a session and sending of control cmds by client) |
23 |
Telnet |
Terminal emulation |
25 |
SMTP |
53 |
DNS |
Translation of domain names into IPs |
80 |
HTTP |
Webserver |
110 |
POP3 |
Client access for email server |
443 |
HTTPS |
Safe web server |
502 |
ModBus/TCP |
Modbus on TCP / Server-Client based (e.g. HMI) |
1202 |
Network Variables |
CoDeSys Network variables based on UDP Broadcast |
1194 |
OpenVPN |
Secure tunnel through the Internet, Remote Maintenance |
1293 |
IPSec |
Secure communications by authenticating and encrypting each IP packet of a data stream |
3389 |
Remote Desktop Protocol |
Windows remote desktop access, windows terminal services |
27126, |
Netmanage |
Based on UDP Broadcasts |
Explanation:
PacDrive3 specific
Port number |
Protocol |
Description |
69 |
TCP |
TFTP Drives Assistant |
1105 |
TCP |
Remote (not inside local subnet) communication SoMM, Controller Assistant, Diagnostics |
1217 |
TCP |
Gateway server (SoMM - gateway) |
1740 - 1743 |
UDP |
Gateway server (gateway - controller) |
4840 |
TCP |
OPC UA |
5000 |
TCP |
PacDriveM compatibility services (e.g. read/ write marker address), Diagnostics |
8080 |
HTTP |
Web vis |
11740 |
TCP |
TCP block driver (remote OPC connection) |
35021 |
UDP |
Local broadcast SERCOS III NRT requests/responses Drives Assistant |
50000 |
TCP / UDP |
NAT communication to SLC |
PacDriveM specific
Port number |
Service |
Description |
1210, 1211 |
Gateway Server |
CoDeSys communication server to handle multiple client applications simultaneously to the runtime. |
5000 |
ARTI |
CoDeSys TCP/IP communication |
Additional Schneider tools
Port number |
Protocol |
Description |
8080 |
Http |
License Manager |
8090 |
floating license Manager |
27010 |
27011 |
80 |
Http |
Sesu |
8080 |
HTTP |
Sesu |
443 |
HTTPs |
Sesu |
443 |
HTTPs |
Machine Expert installer |
Port number |
Service |
Description |
20 |
FTP |
21 |
FTP |
23 |
Telnet |
25 |
SMTP |
53 |
DNS |
80 |
HTTP |
Webserver |
110 |
POP3 |
443 |
HTTPS |
Safe web server |
502 |
ModBus/TCP |
1202 |
Network Variables |
1194 |
OpenVPN |
1293 |
IPSec |
3389 |
27126, |
Netmanage |
Explanation:
PacDrive3 specific
Port number |
Protocol |
Description |
69 |
TCP |
1105 |
TCP |
1217 |
TCP |
1740 - 1743 |
UDP |
4840 |
TCP |
OPC UA |
5000 |
TCP |
8080 |
HTTP |
Web vis |
11740 |
TCP |
35021 |
UDP |
50000 |
TCP / UDP |
PacDriveM specific
Port number |
Service |
Description |
1210, 1211 |
Gateway Server |
5000 |
ARTI |
Port number |
Protocol |
Description |
8080 |
Http |
License Manager |
8090 |
27010 |
27011 |
80 |
Http |
Sesu |
8080 |
HTTP |
Sesu |
443 |
HTTPs |
Sesu |
443 |
HTTPs |
