Windows Features Not Fully Enabled Causes Security Expert SOAP Service HTTP 404 Error
Select a Country
  • Windows Features Not Fully Enabled Causes Security Expert SOAP Service HTTP 404 Error
  • RandyDavis
    RandyDavis
  • AdamSteele
    AdamSteele
  • AbeMeran
    AbeMeran
AbeMeran Mentor
‎2021-02-04 06:36 AM
Last Updated: AdamSteele Champion ‎2026-08-05 06:52 PM
The Security Expert SOAP service cannot be reached at:
http://localhost:8030/SecurityExpertSOAPService/service.svc
or
https://localhost:8040/SecurityExpertSOAPService/service.svc
When browsing to the service URL, an HTTP 404 error is displayed.
EcoStruxure Security Expert
Security Expert Server
There can be confusion regarding how Windows indicates whether features are enabled.
The Security Expert SOAP Service installation documentation shows a checkmark next to the required.NET Framework feature. A checkmark indicates that the feature and all associated sub-features are enabled.
If only some sub-features are enabled, Windows displays the feature with a black square (filled checkbox) instead of a checkmark. This state is often misinterpreted as meaning the feature is fully enabled when it is not.
Windows Feature Indicators
To verify exactly what is enabled, expand the parent feature and inspect the child items individually.
Indicator Meaning
☑ Checkmark Parent feature and all child features enabled
◼ Black square Partial selection. Some child features enabled, others not
☐ Empty box Feature disabled
When a feature check box is shown with a checkmark in the documentation:
  • Expand the feature in Windows Features.
  • Verify that all sub-features under the parent feature are enabled.
  • Do not assume that a black square (filled checkbox) indicates the same state as a checkmark.
  • Ensure the feature state matches the documented configuration before installing or troubleshooting the SOAP service.
All required sub-features must be enabled for the feature to match the documented configuration.
  • EcoStruxure Security Expert
Tags (5)
  • 404
  • AbeMeran21
  • AdamSteele23
  • AdamSteele26
  • feature
100% helpful (1/1)
