What to Validate After Upgrading EcoStruxure Building Operation
Select a Country
  • What to Validate After Upgrading EcoStruxure Building Operation
  • RobertAndriolo
    RobertAndriolo
RobertAndriolo Champion
‎2026-06-14 09:19 PM
on ‎2026-06-14 09:19 PM
  • No standard test or performance validation procedure is available.
  • Each EcoStruxure Building Operation system requires a site-specific approach based on its configuration.
  • Guide on what to check after EBO / Windows updates
  • Enterprise Central (EC)
  • Enterprise Server (ES)
  • Automation Server (AS)
  • WebStation
  • WorkStation
  • PostgreSQL / Timescale Database (if used)
  • SQL Server (if used)
  • External databases (if used)
  • Third-party interfaces (if used)
When validating system performance (for example, after an upgrade or Windows updates), a standard procedure may be expected; however, EcoStruxure Building Operation systems differ significantly in server roles, databases, and integrations, requiring a site-specific validation approach.
Use the following structured approach to create and execute a site-specific performance validation procedure for EcoStruxure Building Operation systems.
1. Prepare Baseline (Before Changes)
Capture current system performance to enable comparison.
  • Record CPU usage (Enterprise Central / Enterprise Server)
  • Record memory usage (Enterprise Central / Enterprise Server)
  • Measure network latency between Enterprise Central / Enterprise Server and Automation Servers
  • Capture system load indicators:
    • Active alarms
    • Trend logs
    • Connected users
  • Measure user experience:
    • WebStation load times
    • WorkStation login times
    • Graphics load performance
2. Perform Immediate Post-Change Validation
Confirm the system is operational after updates or changes.
  • Confirm all servers are online
    • Expected result: No offline or red cross states
  • Verify licenses are valid
  • Confirm all required services are running
  • Validate communication between:
    • Enterprise Server
    • Automation Servers
3. Inspect Logs and System Health
Identify early warnings or failures.
  • Review Windows Event Viewer
  • Review EcoStruxure Building Operation logs
  • Check for:
    • Service failures
    • Certificate issues
    • Database warnings
4. Verify Core Functionality
Ensure key features are operating correctly.
  • Verify alarm generation and acknowledgment
  • Confirm trend data is being recorded
  • Validate graphics loading and bindings
  • Test access via:
    • WorkStation
    • WebStation
    • Mobile clients (if applicable)
5. Validate Performance
Assess system responsiveness and resource usage.
  • Validate WebStation responsiveness
    • Expected result: Acceptable page load and navigation times
  • Monitor CPU usage trends
  • Monitor memory usage trends
  • Check database performance
    • Trend retrieval speed
    • Alarm list loading
  • Verify network latency
  • Confirm communication stability
    • Expected result: No intermittent offline or red cross states
6. Perform Soak Testing (24–72 Hours)
Validate stability under normal operating conditions.
  • Operate the system under typical load
  • Monitor:
    • CPU stability
    • Memory trends
    • Communication reliability
  • Confirm no gradual performance degradation
7. Confirm Regression Checks
Ensure no functional or performance regression.
  • All servers remain online
  • No communication drops
  • WebStation operates reliably
  • Trends and alarms function correctly
  • Reports generate successfully
8. Define Rollback Plan
Prepare recovery actions if issues are identified.
  • Define rollback criteria:
    • Persistent communication issues
    • Sustained high resource usage
    • Performance degradation
    • Database latency issues
  • Define rollback method:
    • Restore from backup
    • Revert to the virtual machine snapshot
9. Document and Sign Off
Capture results and confirm validation completion.
  • Record system version and Windows update details
  • Document test results and identified issues
  • Obtain stakeholder or customer sign-off
Reference Materials
Use relevant documentation to support the validation approach:
  • EcoStruxure Building Management Overview
  • Architectural Guidelines
  • Backup and Restore Overview
  • Information Technology System Planning Guide
  • Hardening Guidelines Overview
  • RobertAndriolo26
