Using Digital Point Cards (DPC‑3‑1 / DPC‑3‑2) with a Network 8000 MicroZone II Controller
Select a Country
  • Using Digital Point Cards (DPC‑3‑1 / DPC‑3‑2) with a Network 8000 MicroZone II Controller
  • CraigEl
    CraigEl
‎2018-09-07 04:19 AM
Last Updated: CraigEl Champion ‎2026-03-02 10:37 PM
Guidance on how to configure and use digital point cards with a Network 8000 MicroZone II controller.
TAC IA Series
  • Network 8000 MicroZone II controller
  • Digital Point Card
MicroZone II controllers do not natively interpret the digital input signals from DPC‑3‑1 and DPC‑3‑2 cards. A custom application file is required for these cards to function correctly.
To enable digital input support on a MicroZone II controller:
  1. Download and load the custom application file
    Use the attached application file 1‑DPC3.MZ2. This file enables the controller to correctly process signals from the DPC‑3‑1 and DPC‑3‑2 digital point cards.
  2. Refer to the attached technical bulletin
    The attached TB01‑26 document provides detailed information on:
    • Supported digital point card models
    • Hardware installation
    • Wiring considerations
    • Application behavior and configuration steps
  3. Compatibility note
    • DPC‑3‑1 and DPC‑3‑2 are the only digital point cards supported by the MicroZone II controller.
    • DPC‑5 series cards were designed for MNL and MNB controllers. They can be used with the DUI Expander Object, but not with standard MicroZone II applications.
(Note: The DPC-5 series cards were designed for the MNL and MNB controllers.  They are compatible with the DUI Expander Object available for both controller lines.)
  • TAC IA Series
1-DPC3.zip
Tags (3)
  • 3189
  • CraigEllis23
  • CraigEllis26
100% helpful (1/1)
