Troubleshooting License Entitlement Assignment for AS-B and AS-P in EBO 2022 (4.0) and Later
Select a Country
  • Troubleshooting License Entitlement Assignment for AS-B and AS-P in EBO 2022 (4.0) and Later
  • CraigEl
    CraigEl
CraigEl Champion
‎2025-11-26 04:44 PM
Users encounter problems assigning entitlement licenses to AS-B and AS-P controllers in EcoStruxure Building Operation (EBO) 2022 (4.0) and later using Device Administrator.
Common symptoms include:
  • Entitlement assignment fails.
  • The assignment option is greyed out.
  • No license product appears after the entitlement is added.
  • "No valid license found" is displayed.
  • The entitlement is visible in Device Administrator but cannot be assigned to the controller.
  • A newly purchased license appears incompatible with the controller.
  • EcoStruxure Building Operation 2022 (4.x) to 2024 (6.x)
  • Device Administrator
  • Building Operation Automation Server
    • AS-P
    • AS-P-NL
    • AS-P-S
    • AS-P-NLS
    • AS-B
    • AS-B-P Family
Starting with EBO 2022 (4.0), Schneider Electric introduced a scalable licensing model that decouples hardware and software.
As a result, two different licensing models exist for AS-P and AS-B controllers:
  • Older controller hardware requires an Upgrade License.
  • Newer controller hardware requires a Bundle License.
If an Upgrade License is purchased for hardware that requires a Bundle License, or a Bundle License is purchased for hardware that requires an Upgrade License, Device Administrator will not allow the entitlement to be assigned to the controller.
This is the most common cause of entitlement assignment failures in EBO 2022 and later.
Automation Server License Assignment Guide
I cannot assign my AS-P or AS-B license
Step 1
Find the Automation Server hardware part number from the controller properties or the controller label.
Do not rely only on the model name (AS-P or AS-B). The required license depends on the hardware part number.
Match your hardware to the correct license
AS-P Upgrade
Hardware
  • SXWASPXXX10001
  • SXWASPXXX10002
  • SXWASPXXX1S001
Use an AS-P Upgrade License
  • SXWSWASPUPxxxx
AS-P Bundle
Hardware
  • SXWASPSBX10001
  • SXWASPSBX10002
  • SXWASPSBX1S002
Use an AS-P Bundle License
  • SXWSWXBUxxxxxx
AS-B Upgrade
Hardware
  • SXWASB24X10001
  • SXWASB24H10001
  • SXWASB36X10001
  • SXWASB36H10001
Use an AS-B Upgrade License
  • SXWSWASBUPxxxx
AS-B Bundle
Hardware
  • SXWASB24PX10001
  • SXWASB24HP10001
  • SXWASB36PX10001
  • SXWASB36HP10001
Use an AS-B Bundle License
  • SXWSWXBBUxxxxx
⚠ License Mismatch
If the purchased license does not match the Automation Server hardware, Device Administrator will not allow the entitlement to be assigned.
Purchased the wrong license?
If the entitlement has not been consumed or assigned, contact your local Schneider Electric Order Entry or Customer Care team to discuss returning the unused entitlement and purchasing the correct license.
AS-P Hardware Compatibility
Hardware Part Number Model Required License Type
SXWASPXXX10001 AS-P AS-P Upgrade License
SXWASPXXX10002 AS-P-NL AS-P Upgrade License
SXWASPXXX1S001 AS-P-SMK AS-P Upgrade License
SXWASPSBX10001 AS-P-S AS-P Bundle License
SXWASPSBX10002 AS-P-NLS AS-P Bundle License
SXWASPSBX1S002 AS-P-NLS-SMK AS-P Bundle License
Examples of AS-P Upgrade License Part Numbers
  • SXWSWASPUP30SA
  • SXWSWASPUP30SD
  • SXWSWASPUP30EN
  • SXWSWASPUP30FU
  • SXWSWASPUP40SA
  • SXWSWASPUP40SD
  • SXWSWASPUP40EN
  • SXWSWASPUP40FU
Examples of AS-P Bundle License Part Numbers
  • SXWSWXBU0000SA
  • SXWSWXBU0000SD
  • SXWSWXBU0000EN
  • SXWSWXBU0000FU
AS-B Hardware Compatibility
SXWASB24X10001 AS-B-24 AS-B Upgrade License
SXWASB24H10001 AS-B-24H AS-B Upgrade License
SXWASB36X10001 AS-B-36 AS-B Upgrade License
SXWASB36H10001 AS-B-36H AS-B Upgrade License
SXWASB24PX10001 AS-B-24-P AS-B Bundle License
SXWASB24HP10001 AS-B-24H-P AS-B Bundle License
SXWASB36PX10001 AS-B-36-P AS-B Bundle License
SXWASB36HP10001 AS-B-36H-P AS-B Bundle License
Examples of AS-B Upgrade License Part Numbers
  • SXWSWASBUP30SD
  • SXWSWASBUP30FU
  • SXWSWASBUP40SD
  • SXWSWASBUP40FU
Examples of AS-B Bundle License Part Numbers
  • SXWSWXBBU010SD
  • SXWSWXBBU050FU
Example License Mismatch
Controller Hardware:
SXWASB24X10001 (AS-B-24)
Correct License Type:
Incorrect License Type:
SXWSWXBBU050FU (AS-B Bundle License)
Result:
The entitlement will be visible in Device Administrator but cannot be assigned to the controller.
Additional Information
  • Original AS-P and AS-B hardware models require Upgrade Licenses even when running EBO 2022, EBO 2023, EBO 2024, or EBO 6.x.
  • AS-P-S, AS-P-NLS, AS-P-NLS-SMK, and AS-B-P family hardware use the scalable licensing model and require Bundle Licenses.
  • Refer to the latest Part Number Summary and Hardware & Software Matrix when purchasing hardware or licenses.
Tags (2)
  • CraigEllis25
  • CraigEllis26
100% helpful (1/1)
