Sounder Not Activating When Input Module Is Triggered via Beam Detector Output
Select a Country
  • Sounder Not Activating When Input Module Is Triggered via Beam Detector Output
  • Sandeep_Kumar006
    Sandeep_Kumar006
Sandeep_Kumar006 Troubleshooter
‎2026-04-23 04:00 PM
The wall-mounted sounder does not activate when the input module is triggered through the beam detector output, even though the panel correctly enters an alarm condition.
ESMI Fire Detection.
  • Esmi Sense FDP252 Fire Detection Panel
  • Esmi Impresia Red VAD Wall Mounted Sounder (FFS06741012)
  • Esmi Impresia 2 Inputs/2 Outputs Module (FFS06741007)
A firmware-related issue in MCU version 24.11.6.g (EFO variant, where “G” denotes the EFO version) prevents the wall sounder from activating when the input module is triggered via a beam detector output. This issue occurs even though the fire detection panel correctly processes the alarm condition and the sounder control group is properly configured.
Update the panel MCU firmware to version 24.5.5.f (without EFO version) or later.
Please refer to the O1885GB18 – FDP Installation and Commissioning Manual for detailed firmware upgrade instructions.
  • ESMI Fire Detection
  • SandeepKumar26
