SPP920 Datasheet, Technical Information and Installation Instructions
  • SPP920 Datasheet, Technical Information and Installation Instructions
‎2018-09-10 10:48 PM
Last Updated: Crewman ContentModerator ‎2025-08-11 03:53 AM
Field Device
SPP920 Differential Pressure Switch
No information available for the SPP920. The Sensor catalogue says it is supported by Huba.
Either click link www.hubacontrol.com and search for 630.
or the
Technical information can be downloaded here.
Installation Instructions can be downloaded here.
Mechanical connections are: P1 = High Pressure (discharge/flow), P2 = Low Pressure (suction/vacuum)
All of the various pressure range options come with the following options:
- EPDM diaphram material
- Brass Case
- Spec Cover PG9 - IP65 Rating
- Bracket Type A
  • Field Devices
Tags (2)
  • 8228
  • DavidChild19
100% helpful (3/3)
