Resolving Device Administrator Licensing Error "No EmbeddedLicensingRespone"
Select a Country
  • Resolving Device Administrator Licensing Error "No EmbeddedLicensingRespone"
  • RobertAndriolo
    RobertAndriolo
RobertAndriolo Champion
‎2026-03-29 10:37 PM
Attempts to assign or activate embedded or software licenses in Device Administrator fail when working with an Enterprise Server and Automation Servers running significantly older firmware versions (e.g., ES 3.2.x) than the DA version (DA 7.1.x) in use.
Licensing attempts fail, returning No EmbeddedLicensingResponse from the ES.
Sample messages from Device Administrator: "Detailed progress Dialogue box"
  • Executing embedded operation: Activate ActivationID: ACT-xxxx-xxxx-xxxx
  • Failed to run script .\PythonActions\executelicensingcommand.py with arguments .\PythonActions\executelicensingcommand.py .... EmbeddedLicensingRespone returned from the server.
  • Embedded operation: Activate failed: No EmbeddedLicensingRespone returned from the server.
  • EcoStruxure Building Operation Device Administrator (DA)
  • EcoStruxure Building Operation Enterprise Server (ES)
  • EcoStruxure Building Operation Automation Servers (AS)
  • Upgrading from version 3.2x to v7.0 / v7.1 / v7.1.1.132 and above
Device Administrator 7.1 cannot activate licenses on an Enterprise Server running version 3.2.x because the two versions use different licensing systems. Over time, EcoStruxure Building Operation introduced major changes to how embedded licensing works (between versions 3.x and 7.x). As a result, an older ES cannot understand the licensing requests sent by the newer Device Administrator. This mismatch causes the server to return no response, resulting in the error “No EmbeddedLicensingResponse.”
Upgrade target servers (ES/AS) to the desired Building Operation major version before attempting to activate the license using Device Administrator.
Always use the latest supported Device Administrator version for the Building Operation version in use.
  • RobertAndriolo26
