Welcome to the new Schneider Electric Community
It's your place to connect with experts and peers, get continuous support, and share knowledge.
  • You may be familiar with Communities' brand new layout from SE.com.
  • Don't forget to update your bookmarks and saved links with our new address (https://community.se.com/).
  • If you encounter any issues, please contact SchneiderCommunity.Support@se.com.
Sign In Help
Important Announcement: WELCOME to the Schneider Electric Community! We have moved to a new address: community.se.com — bookmark it today and contact SchneiderCommunity.Support@se.com if you have any questions!
Ask the Community Community Guidelines Community User Guide How-To & Best Practices Contact Support
Community Menu
  • Community Home
    • By Topic
        • Support
        • EcoStruxure Building
          • Field Devices Forum
        • EcoStruxure Power & Grid
          • EcoStruxure Energy Hub User Group
          • Gateways and Energy Servers
          • EcoStruxure IT forum
        • Remote Operations
          • Remote Operations Forum
        • Industrial Automation
          • Industrial Edge Computing Forum
          • Alliance System Integrators Forum
          • Machine Automation Forum
          • EcoStruxure Automation Expert / IEC 61499 Forum
          • AVEVA Plant SCADA Forum
          • Modicon PAC Forum
          • Harmony Control Customization Forum
          • Level and Pressure Instrumentation Forum
          • PLC Club Indonesia
          • Fabrika ve Makina Otomasyonu Çözümleri
          • Motorabgangstechnik & Antriebstechnik Forum
          • Korea Industrial Automation Forum
        • Power Distribution IEC
          • Power Distribution and Digital
          • Solutions for Motor Management
          • Paneelbouw & Energie Distributie
          • Eldistribution & Fastighetsautomation
          • Elektrik Tasarım Dağıtım ve Uygulama Çözümleri
          • Електропроектанти България
          • Specifiers Club ZA Forum
        • Power Distribution NEMA
          • Power Monitoring and Energy Automation NAM
        • Power Distribution Software
          • EcoStruxure Power Design Forum
          • LayoutFAST User Group Forum
        • Solutions for your Business
          • Solutions for your Business Forum
      • Support
      • Remote Operations
        • Modicon PAC Forum
      • Food & Beverage
      • Healthcare
    • Geo SCADA Knowledge Base
    • Industrial Automation How-to videos
    • Digital E-books
    • Success Stories Corner
  • Success Stories
    • All Events
    • Innovation Talks
    • Innovation Summit
    • Let's Exchange Series
    • Technology Partners
    • Power Events & Webinars
    • Partner Success
    • Process Automation Talks
        • Remote Operations
          • EcoStruxure Geo SCADA Expert Ideas
          • Remote Operations Devices Ideas
          • Modicon Ideas & new features
    • By Topic
          • Backstage Access Resources
        • Remote Operations
          • Remote Operations Blog
          • Industry 4.0 Blog
          • Industrie du Futur France
          • NEMA Power Foundations Blog
          • Digital E-books
      • Remote Operations
        • Industry 4.0 Blog
        • Digital E-books
Send a co-worker an invite to the Exchange portal.Just enter their email address and we’ll connect them to register. After joining, they will belong to the same company.
  • Communities
  • Replacement of Satchwell ALE series Linear Actuator by S-E M800 Linear Actuator due to obsolescence. (Actuator Selection)
How can we help?
82701members
350436posts
  • Article History
Share
‎2018-09-07 06:43 AM
Satchwell ALE series Linear Actuator requires replacement.
Satchwell ALE series Linear Actuator installed on Satchwell MJF, MZ, MZF, VJF, VSF, VZ or VZF series Plug and Seat Valve Body.
Actuator type :- ALE series.
Obsolescence of Satchwell ALE series Linear Actuator.
Replace Satchwell ALE series Linear Actuator with S-E M800 Linear Actuator and Linkage Kit :-
Linkage kit to mount a M800 actuator to a Satchwell valve (MZ,MZF, VZ, VZF, VSF and MJF) = L2SV
Replace ALE Actuator with M800 + L2SV combined part number 880-0650-000
Replace ALE with Auxilary Switch kit with M800-S2 + L2SV combined part number 880-0651-000
Just linkage kit = 880-0124-000
Just M800 = 880-0310-030
N.B.
Should the Satchwell ALE series Actuator include a wired Auxiliary Switch then the following Accessory should also be installed on the S-E M800 Actuator as appropriate :-
S2 - Two independent 24 volt 4amp AC-1 rated SPDT Auxiliary End Point Switches. (880-0104-000)
Particular care should be taken when selecting an S-E Forta M800 Actuator to replace an existing Satchwell ALE series Actuator.
The S-E Forta M800 Actuator may be used to replace an existing Satchwell ALE series Actuator but it should be noted that where an existing Satchwell ALE series Actuator has been connected directly to a Satchwell Controller, an independent Transformer rated to provide the greater level of power required by a single S-E Forta M800 Actuator (50VA) will also be required. (e.g. S-E Transformer Type TR60)
Where an existing Satchwell ALE series Actuator has been connected via an independent Transformer, it is possible that the Transformer may have been rated to provide the level of power required by a single ALE series Actuator (9.5VA) only.
In such circumstances the existing independent Transformer may also require replacement by another independent Transformer, rated to provide the greater level of power required by a single S-E Forta M800 Actuator (50VA) (e.g. S-E Transformer Type TR60)
Details of the Schneider Electric M800 Actuator may be viewed here
Details of the Schneider Electric TR60 Transformer may be viewed here
  • Field Devices
  • 4662
100% helpful (1/1)
Share
  • Gary
    Gary
  • twitter
  • facebook
  • linkedin
  • youtube
  • blog
  • instagram
You can subscribe to this forum after you log in or create your free account..
Already have an account?Login
Privacy Notice Terms of Use Customize Preferences
© 2022, Schneider Electric
