Loytec NIC-852 Appears Offline After Upgrade
Select a Country
  • Loytec NIC-852 Appears Offline After Upgrade
  • PeterLarsen
    PeterLarsen
PeterLarsen Champion
‎2026-06-18 04:37 PM
on ‎2026-06-18 04:37 PM
The Loytec NIC-852 interface remains offline after upgrading from EcoStruxure Building Operation (EBO) 3.2 to EBO 6.0 or later.
  • The interface shows as offline within EBO
  • Testing via the Loytec plugin indicates no issues
  • System logs display the error:
    • NSP.Pin.lon.orion OrionInit returned error code [1]
  • Reverting back to EBO 3.2 restores normal operation, and the NIC-852 comes online without errors
  • EcoStruxure Building Operation WorkStation
  • Loytec NIC-852
  • Loytec software
The Loytec NIC-852 driver is outdated and not compatible with EBO 6.0 and later versions.
Update the Loytec NIC-852 driver:
  1. Download the latest driver from the Loytec website:
    https://www.loytec.com/support/download?view=docman/NIC852-SW
  2. Create and log in to a Loytec user account to access the download
  3. Install the updated driver for the NIC-852
  4. Once updated, the NIC-852 will come online in EBO 6.0 and later versions
  • PeterLarsen26
