IEEE 802.1X on Linux-based Edge Server
Select a Country
  • IEEE 802.1X on Linux-based Edge Server
  • MikaelKrantz
    MikaelKrantz
MikaelKrantz Champion
‎2026-09-03 04:07 AM
IEEE 802.1X Operational Certificate on a Linux-based Edge Server using Device Administrator.
EcoStruxure Building Operation.
  • Linux-based Edge Server
  • Device Administrator
  • BACnet/SC certificate management
IEEE 802.1X is not supported on Edge Servers. IEEE 802.1X operates at Layer 2 of the OSI model and is intended for authentication between physical network devices and network infrastructure.
Edge Server is a software-only component and does not function as a Layer 2 network device.
  • MikaelKrantz26
