Continue
  • My Subscriptions
  • Events
How to Change an Existing Enterprise Download Server Deployment from Typical to Large
  • How to Change an Existing Enterprise Download Server Deployment from Typical to Large
  • AndreasP
    AndreasP
AndreasP Contributor
‎2026-11-04 02:51 PM
on ‎2026-11-04 02:51 PM
An existing Security Expert Enterprise Download Server is deployed using the Typical deployment size and needs to be changed to the Large deployment size.
EcoStruxure Security Expert
  • Security Expert Server
  • Security Expert Enterprise Download Server
The deployment size of an existing Enterprise Download Server cannot be changed in place.
  • A Typical deployment cannot be converted to Large by changing the deployment size of the existing virtual machine.
  • A new Enterprise Download Server virtual machine must be deployed using the Large deployment size.
  • The new virtual machine must be allocated the CPU cores, RAM, and disk capacity required for the Large deployment size.
  • Controllers must be paired with the newly deployed Enterprise Download Server.
To change an existing Enterprise Download Server deployment from Typical to Large, deploy a new Large Enterprise Download Server and retain the existing Typical deployment until the new environment has been successfully validated.
Prepare for the migration:
  • Plan an appropriate maintenance window for the Enterprise Download Server migration.
  • Create a current backup of the Security Expert SQL databases. The required Security Expert system data used by the software is stored in the SQL database tables.
  • Be aware that historical log data stored locally on the existing Enterprise Download Server will not be available after the old virtual machine is deleted.
Deploy the new Enterprise Download Server:
  1. Shut down the existing Enterprise Download Server virtual machine. Do not delete it at this stage.
  2. Start a new Enterprise Download Server deployment.
  3. Select Large as the deployment size.
  4. Ensure that the new virtual machine is allocated the required number of CPU cores, RAM, and disk capacity for a Large deployment.
  5. Complete the Enterprise Download Server deployment process.
  6. Pair all controllers with the newly deployed Enterprise Download Server.
Validate the new deployment:
  • Confirm that the new Enterprise Download Server virtual machine is running.
  • Confirm that the Enterprise Download Server was deployed using the Large deployment size.
  • Confirm that the virtual machine resources meet the Large deployment prerequisites.
  • Confirm that all controllers are successfully paired with the new Enterprise Download Server.
  • Confirm that controller communication and downloads through the new Enterprise Download Server are operating successfully.
Remove the previous deployment:
After the Large Enterprise Download Server has been successfully validated and all controllers are operating through the new deployment, the previous Typical Enterprise Download Server virtual machine can be deleted.
  • EcoStruxure Security Expert
  • AndreasPettersen26
