Execution Precedence Sets Program Execution Order but Not Priority
Select a Country
  • Execution Precedence Sets Program Execution Order but Not Priority
  • RobertAndriolo
    RobertAndriolo
  • PaulFr
    PaulFr
‎2018-09-06 11:59 AM
Last Updated: RobertAndriolo Champion ‎2026-08-17 09:51 PM
  • Can Execution Precedence be used to determine the priority of a program that is bound to a value?
  • Application Task shows the "Conflicts" property set to true
  • High Memory/CPU values causing performance issues with Automation Servers running a large number (100+) of applications (Function Block Programs and Script Programs)
  • Building Operation Automation Server (AS. AS-B, AS-P, AS-P-3)
  • Function Block programs
  • Script programs
The behavior of the Execution Precedence property is often misunderstood. Execution Precedence is intended to help the Application Scheduler establish a valid execution sequence between dependent programs. It does not provide a program priority mechanism and cannot be used to determine which program has control of a value when multiple programs are bound to the same output. Incorrect assumptions about its purpose can result in dependency-cycle issues, application conflicts, or unexpected control results
Execution Precedence is a program property available in both Function Block and Script programs. It is configured from the program Properties on the Basic tab.
How Execution Precedence Works
Execution Precedence controls the order in which programs are executed.
  • Programs with lower Execution Precedence values execute before programs with higher values.
Program execution is coordinated by the Application Scheduler. For synchronized tasks, the scheduler normally determines execution order by analyzing dependencies between program inputs and outputs.
  • Applications that provide data are generally executed before applications that consume that data.
Programs with the Same Execution Precedence
If multiple programs have the same Execution Precedence value, Execution Precedence does not establish an execution-order preference between them.
In this situation, the Application Scheduler determines the execution order based on program dependencies.
Important: Programs with equal Execution Precedence values should not be assumed to execute in a specific order unless that order is defined by their dependencies.
Using Execution Precedence for Dependent Programs
Execution Precedence can be used when one program generates a value that is required by another program.
Example
  • Program A calculates a compensated setpoint.
  • Program B is a PID control program that uses the compensated setpoint as its reference value.
  • Program B must have a higher Execution Precedence value than Program A so that the compensated setpoint is calculated before the PID program executes.
Resolving Dependency Cycles
A dependency cycle occurs when two or more programs depend on each other, preventing the Application Scheduler from determining a valid execution order.
Example
To resolve a dependency cycle:
  1. Identify the program that should execute first.
  2. Assign that program a uniquely lowest Execution Precedence value.
  3. The Application Scheduler uses that value to establish a valid execution order.
Example
  • Program A: Execution Precedence = 10
  • Program B: Execution Precedence = 20
Result:
  • Program A executes first.
  • Program B executes second.
Note: If multiple programs within the dependency cycle share the same lowest Execution Precedence value, Execution Precedence does not provide a tie-break mechanism and cannot be used to resolve the cycle.
What Execution Precedence Does Not Do
Execution Precedence affects execution order only.
It does not affect program priority.
If two programs are bound to the same value output, both programs attempt to control that value, resulting in an indeterminate outcome.
Combining Outputs from Multiple Programs
When outputs from multiple programs must be combined, use appropriate logic.
Binary values
  • AND
  • OR
  • XOR
  • Other logical operators
Analog values
  • Maximum
  • Minimum
  • Average
  • Other methods appropriate for the application requirements
References
EcoStruxure Building Operation WebHelp:
  • Application Scheduler
  • Program Cycles in EcoStruxure Building Operation Software
  • Script Programs
Tags (2)
  • 11172
  • RobertAndriolo26
100% helpful (1/1)
