Error Saving Automation Server Backup with "Value Does Not Fall Within the Expected Range"
Select a Country
  • Error Saving Automation Server Backup with "Value Does Not Fall Within the Expected Range"
  • CraigEl
    CraigEl
CraigEl Champion
‎2026-07-29 01:37 AM
on ‎2026-07-29 01:37 AM
When attempting to use the Save To function to create a local AS-P backup, WorkStation displays the error message "Value does not fall within the expected range" and the backup cannot be saved.
  • Building Operation WorkStation
  • Building Operation Automation Server
The issue is related to the backup path stored in the WorkStation user profile, where the previously used save location is no longer available.
Close all WorkStation instances and delete the contents of the following folder:
%appdata%\Schneider Electric EcoStruxure\Building Operation\WorkStation
After clearing the WorkStation profile data, reopen WorkStation and perform the backup again.
The issue is resolved if the backup completes successfully and no error message is displayed.
  • CraigEllis26
