Continue
  • My Subscriptions
  • Events
Driver loading disabled alarm appears after upgrading EcoStruxure Building Operation
  • Driver loading disabled alarm appears after upgrading EcoStruxure Building Operation
  • CraigEl
    CraigEl
CraigEl Champion
‎2026-10-29 08:49 PM
on ‎2026-10-29 08:49 PM
A "Driver loading disabled" system alarm appears after upgrading EcoStruxure Building Operation. The alarm can appear even when no SmartDrivers are installed or being used.
  • Building Operation Automation Server Premium (AS-P)
  • Building Operation SmartDriver
As noted in the EBO Webhelp Load SmartDriver Drivers at Startup topic, SmartDrivers are loaded at server startup by default. If a faulty SmartDriver causes the EBO server to crash repeatedly, the server disables SmartDriver loading to prevent further crashes. SmartDriver loading can also have been manually disabled. In earlier versions, a system alarm was not triggered when SmartDriver loading was disabled. After upgrading, the disabled state generates the "Driver loading disabled" system alarm.
  1. Re-enable SmartDriver driver loading on the affected Enterprise Server or Automation Server from System > SmartDrivers > Properties.
  2. Warm start the server.
  3. Verify that the SmartDriver loading disabled alarm is cleared.
  • CraigEllis26
100% helpful (1/1)
