DALI Emergency Status Light – Interpretation of Status Values
Select a Country
  • DALI Emergency Status Light – Interpretation of Status Values
  • Katha
    Katha
Katha Troubleshooter
‎2026-07-31 06:16 PM
on ‎2026-07-31 06:16 PM
The DALI Emergency Status Light object contains several status-related properties that are represented as an Integer value. Each Integer value corresponds to one or more status flags reported by the DALI device.
The purpose of this article is to provide a clear mapping between the Integer values and their corresponding flags for each DALI Emergency Status property.
Dali Expansion Module
DALI Emergency Status properties are reported as integer values that represent one or more status flags combined using a bitmask calculation. A single displayed value may therefore correspond to multiple active device conditions.
The DALI Emergency Status Light object reports several status-related properties as Integer values. Each value represents one or more active status flags using a bitmask calculation.
How to interpret a status value
  1. Identify the property being evaluated (for example, Emergency Mode or Emergency Status).
  2. Locate the corresponding flag table below.
  3. Compare the reported Integer value against the available flag values.
  4. Determine which flag values add up to the reported Integer value.
  5. The resulting flags represent the current state reported by the DALI emergency device.
Example
A device reports an Emergency Mode value of 10.
Value Flag
2 Normal Mode
8 Extended Emergency Mode
Because:
10 = 8 + 2
the following flags are active:
  • Normal Mode
  • Extended Emergency Mode
Multiple flags can be active simultaneously, resulting in a combined Integer value.
Light Information
Value Flag
1 Control gear failure
2 Lamp failure
4 Lamp on
8 Limit error
16 Fade running
32 Reset state
64 Short address not assigned
128 Power cycle seen
Emergency Mode
Value Flag
1 Rest Mode
2 Normal Mode
4 Emergency Mode
16 Function test in progress
32 Duration test in progress
64 Hardwired inhibit is active
128 Hardwired switch is on
Emergency Features
Value Flag
1 Integral emergency control gear
2 Maintained control gear
4 Switched maintained control gear
8 Auto test capability
16 Adjustable emergency level
32 Hardwired inhibit supported
64 Physical selection supported
128 Re-light in rest mode supported
Emergency Failure Status
Value Flag
1 Circuit failure
2 Battery duration failure
4 Battery failure
8 Emergency lamp failure
16 Function test maximum delay exceeded
32 Duration test maximum delay exceeded
64 Function test failed
128 Duration test failed
Emergency Status
Value Flag
1 Inhibit Mode
2 Function test done and result valid
4 Duration test done and result valid
8 Battery fully charged
16 Function test request pending
32 Duration test request pending
64 Identification active
128 Physically selected
Validation
After decoding the reported value, compare the active flags against the current device condition, including:
  • Emergency lighting operating mode
  • Test status
  • Battery status
  • Reported device failures or alarms
Confirm that the decoded flags accurately reflect the observed state of the DALI emergency device before proceeding with further troubleshooting.
Important Notes
  • Each status flag is represented by a unique bit value.
  • Multiple active flags are combined into a single Integer value.
  • A higher value does not necessarily indicate a more severe condition.
  • Always decode the Integer value into its component flags to understand the actual device status being reported.
  • KatharineVasquez26
