- Building Operation Enterprise Server
- Building Operation Enterprise Central
Building Operation Automation Server
Email providers:
Microsoft 365
Google Workspace
Third‑party tool: Email OAuth 2.0 Proxy (from GitHub)
Use a locally installed proxy (Email OAuth 2.0 Proxy) to accept Basic Authentication from EBO and perform OAuth 2.0 authentication with the mail provider.
⚠️ Important Note:
The solution detailed in this article is not officially tested or supported by Schneider Electric R&D.
Configuration steps
Refer to OAuth 2.0 Email Proxy integration with EBO for full details.
1. Install the Email OAuth 2.0 Proxy
- Download the proxy from its GitHub page.
- Install/extract the application on either:
- the same Windows machine as the EBO server.
- a Windows computer in the same network.
2. Generate OAuth 2.0 Client Credentials
Google Gmail
- Create a Google Cloud project.
- Generate Client ID and Client Secret.
Microsoft 365
- Register an app in Microsoft Azure.
- Generate Client ID and Client Secret (one‑time visibility).
- Enable SMTP Authentication for the mailbox.
3. Configure the Proxy
The proxy uses a single configuration file stored in the same folder as emailproxy.exe.
Key sections include:
[emailproxy]– token handling, encryption[SMTP-XXXX]– local listener and SMTP relay mapping[user@provider.com]– OAuth credentials for each account
Sample configuration
[emailproxy]
delete_account_token_on_password_error = True
encrypt_client_secret_on_first_use = False
[SMTP-2588]
server_address = smtp-mail.outlook.com
server_port = 587
server_starttls = True
local_address = 127.0.0.1
local_port = 2588
[SMTP-2587]
server_address = smtp.gmail.com
server_port = 587
local_port = 2587
[**@outlook.com]
permission_url = https://login.microsoftonline.com/common/oauth2/v2.0/authorize
token_url = https://login.microsoftonline.com/common/oauth2/v2.0/token
oauth2_scope = https://outlook.office.com/IMAP.AccessAsUser.All https://outlook.office.com/POP.AccessAsUser.All https://outlook.office.com/SMTP.Send offline_access
redirect_uri = http://localhost:85
client_id = **
client_secret = **
[**@gmail.com]
permission_url = https://accounts.google.com/o/oauth2/auth
token_url = https://oauth2.googleapis.com/token
oauth2_scope = https://mail.google.com/
client_id = **
client_secret = **4. Prepare the System
- Ensure no previous proxy processes are running:
taskkill /f /im emailproxy.exe - Start the proxy by running
emailproxy.exe.
5. Configure EBO SMTP Settings
In EBO WorkStation → Server Properties → Email tab:
| Setting | Value |
| Primary Host | IP of proxy (ex: 127.0.0.1) |
| Port | The local_port defined in proxy config (e.g. 2588) |
| Encryption | None (proxy handles TLS) |
| Sender/Username | Email address sending notifications |
| Password | Any value (used only for token encryption) |
6. Authorize OAuth Account in System Tray
The first time EBO triggers an email, the proxy requires authorization:
- Right‑click the proxy icon in Windows System Tray.
- Navigate to Authorise account → select your email.
- Complete the web‑based OAuth login.
- Successful authorization shows a confirmation window.
7. Configure Proxy to Start Automatically
Option A: Start at login
- Right‑click proxy icon → Start at login
Option B: Start at system startup (no user login)
- Use Windows Task Scheduler:
- General tab → run as System
- Trigger → At startup
- Action → Start
emailproxy.exe - Ensure "Allow task to be run on demand"
8. Validate Email Sending
Check logs for results:
Success
- Proxy log contains:
235 2.7.0 Authentication successful - EBO event: "Email sent successfully"
Failure
- Proxy error such as
535 5.7.139 Authentication unsuccessful - EBO alarm generated
Additional Troubleshooting
Proxy Debug Mode
- Enable via right‑click → Debug mode
Telnet Testing
Use Telnet to test direct SMTP communication.
Network & Firewall Requirements
- Allow outbound EBO → Proxy on local port
- Allow outbound Proxy → Mail provider
- smtp.office365.com:587
- smtp.gmail.com:587
