Configuring Access Expert to use PIV cards with AX-SSC using AC1 downstream devices
Select a Country
  • Configuring Access Expert to use PIV cards with AX-SSC using AC1 downstream devices
  • AbeMeran
    AbeMeran
AbeMeran Mentor
‎2025-11-02 06:50 PM
on ‎2025-11-02 06:50 PM
Guidance is needed to enable reading of PIV (FIPS-201) cards using the AX-SSC controller and AC1 downstream devices within EcoStruxure Access Expert.
AX-SSC
Sites migrating from Continuum systems require a clear, step-by-step process to ensure PIV cards are properly enrolled and recognized in Access Expert.
What is FASC-N?
FASC-N stands for Federal Agency Smart Credential Number. It is a 25-byte (200-bit) identifier embedded in PIV cards, used to uniquely identify the cardholder across federal systems. It is composed of multiple fields, including:
  • Agency Code
  • System Code
  • Credential Number
  • Credential Series
  • Credential Issue
  • Person Identifier
  • Organizational Category
  • Organizational ID
  • Person Org Association
These fields are encoded using Packed Binary Coded Decimal (BCD) with odd parity, and together form a unique string used by access control systems to authenticate users.
Understanding the FASC-N Structure
In the Continuum Personnel object below, the fields highlighted are those that make up the FASC-N
The PIV enrollment tool generates a character string when a card is presented. For example:
32013733334894141152472674132011
This string is composed of the following FASC-N fields:
Field Value
Agency Code 3201
System Code 3733
Credential Number 334894
Credential Series 1
Credential Issue 4
Person Identifier 1152472674
Organizational Category 1
Organizational ID 3201
Person Org Association 1
Note: If no enrollment tool is available, manually concatenate these fields in the order shown to create the FASC-N string.
Configuration Steps
1. Card Format Setup
Configure the card format in Access Expert as follows:
  • Card Format Type: Standard
  • Bit Length: 128
  • Large Encoded Card Number: ✅ Checked
  • Convert 200 FASCN Bit to 128 Bit: ✅ Checked
  • Card Number Starting Bit: 0
  • Card Number Bit Length: 128
2. AX-SSC Controller Configuration
  • Ensure Enable Large Encoded Card Number is checked.
  • Assign the card format created in Step 1 to the controller.
3. Person Object Configuration
  • Navigate to Add Card Assignments.
  • Paste the full FASC-N string into the Display Card Number field. This will auto-populate the Encoded Card Number field.
  • Since the Encoded Card Number field is limited to 16 characters, truncate the string from the end until only 16 characters remain.
  • Paste the full FASC-N string into the Hex Value field.
    ⚠️ Although labeled "Hex Value", enter the string as decimal digits.
  • Save the Person object.
Additional Notes
  • Only the editors mentioned above require configuration for PIV card support.
  • Editors such as Reader, Access Level, etc., do not need special configuration for PIV cards.
  • EcoStruxure Access Expert
  • AbeMeran25
