Continue
  • My Subscriptions
  • Events
Can Enterprise Download Server Be Used with Controller Encryption and HTTPS Certificates?
  • Can Enterprise Download Server Be Used with Controller Encryption and HTTPS Certificates?
  • AndreasP
    AndreasP
AndreasP Contributor
‎2026-11-03 12:45 PM
on ‎2026-11-03 12:45 PM
Enterprise Download Server (EDS) is being added to controllers that already use Controller Encryption and HTTPS certificates. Clarification is required on whether EDS can be used alongside the existing encryption methods and whether there are any compatibility considerations.
EcoStruxure Security Expert
  • Security Expert Server
  • Security Expert SP-C
  • Security Expert Enterprise Download Server
Controller Encryption, HTTPS certificates, and EDS protect different communication links and operate independently:
  • HTTPS certificate: Secures the controller web interface.
  • Controller Encryption: Secures communication between the controller and the Security Expert server using AES-256 with a unique key per controller.
  • Enterprise Download Server (EDS): Secures the EDS-to-controller connection using TLS with a unique X.509 certificate established during EDS pairing.
Enterprise Download Server is supported alongside Controller Encryption and HTTPS certificates, with no known issues using them together.
  • Pairing a controller with EDS establishes the EDS-to-controller TLS connection using a unique X.509 certificate.
  • Controller Encryption does not change or replace this connection.
After adding EDS, confirm the following operate as expected:
  • Events
  • Manual door commands
  • Single-record download
  • Full download through EDS
  • EcoStruxure Security Expert
  • AndreasPettersen26
