ARM64 containerized images are not available for Edge Server
Select a Country
  • ARM64 containerized images are not available for Edge Server
  • CraigEl
    CraigEl
CraigEl Champion
‎2026-10-01 04:39 PM
on ‎2026-10-01 04:39 PM
A customer wants to deploy an Edge Server on ARM64-based hardware that supports Docker containers and is requesting an ARM64 container image. The available Edge Server container images appear to support AMD64 (x86-64) architecture only.
  • Building Operation Edge Server
  • ARM64-based hardware
Edge Server supports AMD64 (x86-64) CPU architecture only. ARM64 container images are not available.
Edge Server container images are currently available only for AMD64 (x86-64) CPU architecture. ARM64 container images are not supported or available for download.
Customers wishing to deploy Edge Server should use supported AMD64 (x86-64) hardware platforms. If ARM64 support is required, submit an enhancement request through the appropriate Schneider Electric channel or engage the local sales representative for further guidance.
Note: Running AMD64 images through emulation on ARM64 hardware may impact performance and is not supported.
