Welcome to the new Schneider Electric Community
It's your place to connect with experts and peers, get continuous support, and share knowledge.
Important Announcement: WELCOME to the new Schneider Electric Community! Community is now no longer part of Exchange, and is now rebranded under se.com. If you have any bookmarks and links saved, we request you to update them to ensure that you continue accessing our community from this new location. For any issues that you might encounter as part of this change, please reach out to SchneiderCommunity.Support@se.com, and the team will help to get your issues resolved.
Send a co-worker an invite to the Exchange portal.Just enter their email address and we’ll connect them to register. After joining, they will belong to the same company.
82422members
349937posts
Evolution 360: Camera Placement and Pixel Density
Archives: Industrial Automation and Control
sesa269896
Schneider Alumni (Retired)
All camera lenses experience a tradeoff between pixel density and angle of view. This is especially true for hemispheric fisheye lenses where the viewing angle is 180 degrees in every direction.
The fine detail and high pixel count required for facial recognition or license plate reading is limited to close-up views. However, there is a very broad section of the view where detection and identification can occur.
Read the attached Evolution 360 Placement Guidelines to learn about the “4 Zones of Coverage”:
  • Movement Detection/Situational Awareness
  • Object Recognition
  • Facial Recognition
  • Facial Identification
Examples in the guidelines show the pixel densities for two five megapixel Evolution 360 cameras mounted at different heights. The first example is mounted 12 feet high and the second example is mounted at 9 feet high.
1 Reply 1
bcooper_nwcu_co
Captain
Captain
Re: Evolution 360: Camera Placement and Pixel Density
Thanks for sharing this article. I have been doing some of this testing myself, and this article outlines the results I found very well. Are there any similar articles that relate to dynamic range and the issues with light and dark areas in the image?
