Welcome to the new Schneider Electric Community
It's your place to connect with experts and peers, get continuous support, and share knowledge.
  • Explore the new navigation for even easier access to your community.
  • Bookmark and use our new, easy-to-remember address (community.se.com).
  • Get ready for more content and an improved experience.
Contact SchneiderCommunity.Support@se.com if you have any questions.
Send a co-worker an invite to the Exchange portal.Just enter their email address and we’ll connect them to register. After joining, they will belong to the same company.
84599members
353867posts
Catalog
Archives: Building Automation and Control
Alex_Bousselin
Lieutenant JG Lieutenant JG
Lieutenant JG
Catalog
Version 1.2.0
Additional links (only for ETS Experts)
10 Replies 10
lluis1986
Cadet
Re: Catalog
Hello. I have a question, could it be possible to add hardware from other brands to the econfigure project? Thanks in advance. Regards.
domotiqa
Lieutenant
Lieutenant
Re: Catalog
Looks like it's possbile with econfigure expert (profil creation)
Smarthome & Smartbuilding Expert
sesa41972_bridg
Cadet
Re: Catalog
Bonjour, lors du choix manuel des actionneurs, il n'est pas possible de choisir un module sortie 16A si on a choisi un éclairage 10A...
domotiqa
Lieutenant
Lieutenant
Re: Catalog
Ce produit n'est pas dans le catalog non plus:
https://www.schneider-electric.fr/fr/product/MTN6221-0319/knx-m-plan---sonde-de-temp%C3%A9rature-int...
sesa106450_brid
Cadet
Cadet
Re: Catalog
I think it is possible to have the ets project afther to do all the process in eConfigure, is it correct??
If the answer is yes, how??
domotiqa
Lieutenant
Lieutenant
Re: Catalog
right corner left ->product->generate ets project
domotiqa
Lieutenant
Lieutenant
Re: Catalog
What about thios problem of 10A on 16A product ? Any new catalog or something else ?
sesa106450_brid
Cadet
Cadet
Re: Catalog
In my eConfigure Lite Version 1.2.0.0 with catalog version 1.2.0 doesn't appear the option generate ETS version.
Just I can export reports and lists but the ETS projet isn't included.
juha_huvilinna_
Cadet
Re: Catalog
I would also like to generate ETS5 project from eConfigure, but I can't find that. I'm seeing the same options as Javier...
domotiqa
Lieutenant
Lieutenant
Re: Catalog
only for econfigure expert I guess
