MQTT Configuration with Azure for EMSE (Vijeo XL)
AVEVA Plant SCADA Forum
A support forum for AVEVA Plant SCADA (formerly Citect SCADA). Share new and exciting product information, connect, learn, and collaborate with the ecosystem of Plant SCADA Users. AVEVA Plant SCADA a reliable, flexible and high-performance Supervisory Control and Data Acquisition software solution for industrial process customers. This forum is to connect, share, learn and collaborate new and exciting product information. Feel free to join and share to your Ecosystem of Plant SCADA Users.
  • Industrial Automation
  • AVEVA Plant SCADA Forum
  • Re: MQTT Configuration with Azure for EMSE (Vijeo XL)
olivier_vallee
Commander olivier_vallee
34
Oncom
Commander Oncom
6
Kien_Mac
Lieutenant JG Kien_Mac Lieutenant JG
2
Back to AVEVA Plant SCADA Forum
budimanc
Ensign budimanc
Posted: ‎2021-02-01 07:01 AM
4607
Dear Schneider,
I need some help in MQTT driver configuration for Ecostruxure Machine SCADA Expert.
Hereby i attached some photos from my Azure portal and also the configuration that i insert from Azure to EMSE.
I still not able to received data from Azure in my EMSE tags.
Hope someone in this forum will help to guide me.
Thx.
Best Regards,
Budiman Chandra
  • Connected Products
  • Edge Control
  • Smart Operations
  • EMSE
  • scada
Replies 6
Rodrigo_Garcia
Commander Rodrigo_Garcia Commander
Posted: ‎2021-02-02 06:44 AM
Hi @TomDroll Could you support on this?
Thnaks!!!!!
Rodrigo G.
Industrial Automation Community manager
TomDroll
Lt. Commander TomDroll Lt. Commander
Posted: ‎2021-02-02 07:14 AM
4581
Hi Budiman, I am not sure if the pictures didn't get posted or if I just cant find them.
A couple of questions, is it safe to assume that the MQTT Broker is running on Azure?  Have you been tried using a free MQTT client like MQTT.fx or MQTT Explorer on the same PC as the EMSE Runtime to confirm you connection to the broker?
Testing with a client like mentioned above will help determine if the issue is the connection to the broker or the configuration in EMSE.
What version of EMSE are you using?
I will look for your reply.
TD
Tom Droll
budimanc
Ensign budimanc
Posted: ‎2021-02-03 04:40 AM
In response to TomDroll
4572
Dear @TomDroll
Hi, thx for the reply n guide for testing using free MQTT client.
It will takes sometime to use free MQTT client to EMSE.
I'm using EMSE v8.1 with Service Pack 2.
Hereby i attached the configuration I've made by using MQTT Azure to EMSE.
Waiting for your reply soon.
Azure MQTT to EMSE.rar
budimanc
Ensign budimanc
Posted: ‎2021-02-06 02:55 PM . Last Modified: ‎2021-02-06 02:55 PM
In response to budimanc
4540
Hi @TomDroll
Still waiting for your guidance.
Thx.
TomDroll
Posted: ‎2021-02-16 10:29 AM
4485
Hi Budimanc, sorry for the delay in response (was on holiday).  I did some research on this topic and it seems that the MQTT library that Azure IoT Hub is different than the EcoStruxure Machine SCADA Expert driver implementation.  We are currently working to resolve the issues and will follow up when an update is released.
Sorry for the troubles.
Is this an active project or testing for a future project?
Tom
Tom Droll
  • EMSE
  • mqtt
budimanc
Ensign budimanc
Posted: ‎2021-02-26 08:28 AM
Hi @TomDroll
I have change my MQTT connection by using AWS IoT Core.
I have also tried to connect AWS Iot Core to publish/subscribe by using MQTT Box and succeed.
But i am still failed in connecting Vijeo XL to AWS Iot Core.
Where should i upload certiicate for VIjeo XL, since AWS Iot Core is using Self Signed Certificate method.
Hereby i try to add new certificate in the Vijeo XL, but seems like the port change to 443 (it should be 8883).
Thx.
Best Regards,
Budiman Chandra
