84255members
353353posts
ups battery
frank.baudette_apc
133
ups battery
This was originally posted on APC forums on 12/1/2008
what is the charging time of the BE550G with a 150 A battery ?
Re: ups battery
This reply was originally posted by Angela on APC forums on 12/1/2008
this has a very tiny charger, only about 3 watts. it will take a very, very long time and as Mike mentioned, APC cannot support any third party battery usage.
3 Replies 3
mtroha_apc
Re: ups battery
Frank,
APC typically recommends that you charge the battery for at least 16 hours to ensure maximum runtime. I am not sure what you mean by a 150A battery though. The standard battery for these units is a APCRBC110 which is a 12V battery system rated at 7Ah. Other battery systems are not supported to be used w/ the BE550G.
-Mike
rau_apc
Re: ups battery
The original battery is 7Amps, right?
If think if it takes 12-16 hours to recharge a fully depleted 7amps battery on this unit, it would take 12-16 hours more for each 7amps added.
These small units are not made to be charging the battery for such a long time nor run for hours after hours, since 150 Amps would make it run for many hours while on battery. The internal circuitry, the inverter, might heat up to a point where it might reduce the unit lifetime at least.
Re: ups battery
