Continue
  • My Subscriptions
  • Events
alarm sounds continuously
  • Re: alarm sounds continuously on my 750 and 350
BillP Leader
2151
Teken
Teken
156
83
Anonymous user
Not applicable
Posted: ‎2021-06-29 05:58 AM . Last Modified: ‎2024-03-21 10:44 PM
2996
evening folk, i have had a be750g for about 2 years now with no problems. about 2 weeks ago the alarm sounded during a particularly nasty storm we were having, and everything shut down as it should. now when i turn on the ups the power button flashes twice a second for about 10 seconds, the alarm sounds, and the power light goes off. the alarm only silences when i turn the unit back off. there are no other indicator lights active when this occurs. the manual states that a continuous alarm indicates a bad battery. i bought a new one from apc, replaced the old one with it, and still get the same behaviour. this occurs with no load on the battery backed outlets, so i am pretty sure it is not an overload condition. any ideas, or is my ups needing a full replacement?
thanks
tom
  • Back-UPS & Surge Protectors
Anonymous user
Not applicable
They were both working perfectly before I moved (from ,NJ to Fla.) when I set up my computers after the move both of the alarms started to sound continuously even without anything being connected to them
Replies 3
BillP Leader
Leader
Hi Tom,
I'm pretty sure the unit is still under warranty if it was bought not more than 3 years ago. Usually it's an overload condition if the unit emits a constant tone with no LEDs, but since you mentioned that the unit still does the same thing with no load, an overload condition is very unlikely. A bad battery however involves the unit having an alternating green/red LED with a constant tone, plus you mentioned that you already tried installing new batts to no avail so most probably its the unit that needs to be replaced, it may already have a failure. I suggest that you get in touch with [tech support |http://www.apc.com/support/contact/index.cfm ] to verify the warranty of the UPS, try and de-energize the unit, see if there's anymore troubleshooting to be done and so you can look into the correct replacement options.
Hope this helps!
Have a nice day
Anonymous user
Not applicable
thanks kulot,
i have contacted tech support, and they are also approaching it from the no load and non-energized approach. i am fixin' to start that in the next 30 mintues, so i'll be sure to update the forum with the results and observations i have.
thanks for the info,
tom
Anonymous user
Not applicable
