84606members
353882posts
Update battery replace date in Smart UPS?
techbadger_apc
437
This was originally posted on APC forums on 6/15/2012
a couple years ago I replaced a battery pack in one of my UPSes that wasn't on a system. I know I was able to update the battery replace date using a terminal program and connecting serially to the UPS.
I know "Y", then "x" displays the battery replace date but I can't find the procedure to write a new date of battery replacement to the field.
What is the procedure?
Thanks!
BKaiser_apc
Re: Update battery replace date in Smart UPS?
This was originally posted on APC forums on 7/24/2012
From what I've read, the system works in Linux. There is software that programs thru the USB or serial port.
http://linux.die.net/man/8/apctest
http://www.imacat.idv.tw/cgi-bin/man/man2html?apctest+8
2 Replies 2
This reply was originally posted by Jonathan on APC forums on 6/18/2012
Hi Stephen,
Although this is not the one that you are looking for, but the APC PowerChute Business Edition can be used to update the battery replacement date. I have never tried changing this using some sort of a code using HyperTerminal or PutTy. Hope this helps.
BKaiser_apc
