84450members
353657posts
SU700inet Battery run time show 1~5 minute, battery capacity show 100%
shindvs_apc
475
This was originally posted on APC forums on 4/25/2008
how to solve problem?
shindvs_apc
This was originally posted on APC forums on 4/26/2008
3 Replies 3
shindvs_apc
Re: SU700inet Battery run time show 1~5 minute, battery capacity show 100%
Is that software key or Hard key ? like security connector?
Whom to call in INDIA MUMBAI?
Vijay
KVAr_apc
Captain
Captain
Turn off the notification beep from the software, then disconnect it from the computer.
Connect two 100W incandescent lamps or 200-250W worth of resistive loads and let the UPS switch to battery. Let it run on battery until it shuts off and clock the time it takes to shut down.
Plug it in, let it charge overnight and when you check the runtime with just the light bulbs connected, it should be reasonably close to what you clocked.
Failing that, go to APCC.com and choose your country, then select support and it'll give you a way to contact tech support.
shindvs_apc
