84759members
354189posts
Replace Battery LED Stays On After Replacing Battery on Back-Ups Pro 650
artmanphoto_apc
138
This was originally posted on APC forums on 6/9/2008
Last week my Back-ups Pro 650 starting alarming with the Replace Battery LED constantly ON. I ordered a replacement battery RBC4 from the APC Online Store.
The battery arrived today and after installing the new battery the Replace Battery LED is still ON and the alarm still sounds periodically.
I did a hot swap of the battery without turning the Back-ups Pro power switch OFF.
Does anyone know why the LED stays on?
Thanks!
artmanphoto_apc
Re: Replace Battery LED Stays On After Replacing Battery on Back-Ups Pro 65
This was originally posted on APC forums on 6/10/2008
EZ Button;
Thanks for your help! I turned the UPS off then back on and the replace battery LED went out. Have a great week!
Bill
2 Replies 2
EZ_Button_apc
Re: Replace Battery LED Stays On After Replacing Battery on Back-Ups Pro 650
The unit just needs to run a self-test to sense the new battery is present. Just power off and on the unit when you get a chance to initiate the test. If you have software installed you can usually run the test through there as well. If you don't run the test, it will automatically run it within the next 2 weeks by default.
Once you run it, that LED should clear up.
artmanphoto_apc
EZ Button;
Bill
