We Value Your Feedback!
Need help with my 650
  • Re: Need help with my 650
2151
Teken
Spock Teken
101
83
Anonymous user
Not applicable
Posted: ‎2021-06-29 07:10 PM . Last Modified: ‎2024-03-21 03:10 AM
1117
The manual says B650MC. The problem is when I have a power outage. The backup does not go on, just a long constant beep. Also when the power does come back on; the unit itself needs to be turned off and turned back on, using the power button in order for items plugged in to get power. This is the main issue, this does not seem right even if battery needs replacing. Is this normal or a bad unit?
The unit is less than a year old, always been plugged in. The actual backup was only needed twice since installed. Both times no backup. I have been home both times, actually power was only loss for about 30 seconds each time and powers 2 water pumps less than 100 watts total.
  • Back-UPS & Surge Protectors
Anonymous user
Not applicable
On the bottom on the software it states there is 60 minutes of battery time. It also stated the unit was working, so I am not sure if I believe anything it says. When I first plugged in the unit it said there was over 400, but rested on the 60 minutes. I am guessing this is an estimate on wattage being used. If you are running a computer and moniter it would be less time than say the water pump I had plugged into it. That would be more than an hour since it would be far less wattage.
Replies 7
It sounds like the unit may have an internal fault. Are you sure it's B650MC and not BK650MC?
Anonymous user
Not applicable
Yes I missed a letter but it is BE650MC.
Is the led lit when this happens? The below description is for a replace battery indication. If there is no LED indication, this is an overload alarm. If it's overloading when it shouldn't be (low or no load), it's likely an internal fault with the unit and it needs to be replaced
Power On/Replace Battery
LED flashes alternately green
and red.
Anonymous user
Not applicable
Over the weekend I plugged the unit into my computer and ran the software. The unit is actually for backup on a water pump. The water pump is maybe 100 watts max. Anyway the software says the battery was at 100% and recharging. I plugged small fan to test the unit. And as soon as the A/C is cut the unit beeps a continuous beep and a red light but no backup for the fan. If you hit the power button twice the unit turned on the fan for maybe a second then it shut off and beeped again. After you turn the A/C back on you have hit the power button twice as before to get the unit to allow A/C to the lamp and a constant green on unit. I plugged the fan into every outlet on the backup side of the unit including the one marked as master none would battery backup.
When the unit is running on A/C the only light is a constant green. Although when you first turn it on, it does blink green for a short time before going constant green. The software has no indications that there is any issues with battery or the unit. I have much cheaper units the battery has lasted years and always worked when needed to. This unit the battery has never needed to run since an outage is rare. I never notice it not working. No beeping or lights in indicate there was a problem until now when the power did cut out on the wall.
What is your runtime showing in the software?
Anonymous user
Not applicable
Are you speaking of the battery run time? I will have to look. There was a number in the lower right but I am not sure what it said or if it was stated in minutes or hours.
Anonymous user
Not applicable
This is a heading
