84826members
354280posts
Battery Maintenance
herohal_apc
147
Battery Maintenance
This was originally posted on APC forums on 2/27/2012
Hello!
Just got a new UPS ES 550G. Seems to work perfectly. I've noticed that there is nothing anywhere about battery maintenance. I've always thought it was a good idea for any battery to at first, charge it fully, then drain it, and repeat this at least 3 times to ensure maximum charge.
Then, periodically, (once/month or so) drain/charge it again.
Is this not a requirement for a UPS system?
Thanks! ...... Hal
Re: Battery Maintenance
This reply was originally posted by Jonathan on APC forums on 2/28/2012
You're welcome Hal.
3 Replies 3
This reply was originally posted by Jonathan on APC forums on 2/27/2012
Hi Hal -
I hope the kbases below could help you out.
[Battery Damage When Battery Is Left Discharged|http://nam-en.apc.com/app/answers/detail/a_id/720/kw/battery]
[What is the expected life of my APC UPS battery?|http://nam-en.apc.com/app/answers/detail/a_id/8301/kw/battery]
herohal_apc
This was originally posted on APC forums on 2/28/2012
Thanks to both posters for good quick answers. I could only pick one as the 'correct' answer, but both were right on. The provided link filled in the gaps. I just wish the instructions were more clear on this since I did a run-time test twice in 2 days. APC cautions against doing this more than twice/year! Hopefully, not too much damage was done. ...
Message was edited by: herohal
You're welcome Hal.
