84449members
353655posts
BE750G: powerchute says "remaining battery charge is 101%, battery is currently charging" what is going on?
daaan_apc
465
This was originally posted on APC forums on 1/5/2014
i just purchased a BE750G the other day. i noticed that half the time i look, powerchute personal edition 3.0.2 says "remaining battery charge is 101%, battery is currently charging". the rest of the time, everything is fine. is something wrong with my unit or battery?
Tags (4)
Re: BE750G: powerchute says "remaining battery charge is 101%, battery is currently charging" what is going on?
This reply was originally posted by Angela on APC forums on 11/20/2015
Unfortunately the user cannot apply this firmware update for this specific UPS model (or most Back-UPS products). If this is bothersome, you'll have to contact tech support for an RMA to replace the entire UPS.
12 Replies 12
This reply was originally posted by Angela on APC forums on 1/6/2014
From my research, it looks like a bug on the UPS firmware side.
Under About under help and support in PowerChute, what is the UPS firmware version? It appears to be very random and what I'd suggest is to perhaps try resetting the UPS and see if it goes away. To reset it, turn off and unplug any attached devices, including the USB cable. Turn the UPS itself off and unplug it from AC power. Disconnect and remove the battery and hold down the power button for about 15 seconds. Reconnect the battery. Reconnect the UPS to AC power and turn it on. Reconnect your attached devices and USB cable and you can then turn them on and re-check PowerChute.
daaan_apc
This was originally posted on APC forums on 1/6/2014
the firmware version is 908.W3.D
daaan_apc
angela, i followed your instructions but the problem still persists.
This reply was originally posted by Angela on APC forums on 1/8/2014
Working on it - let me see what our end game will be. smile I'll report back ASAP.
daaan_apc
This was originally posted on APC forums on 1/10/2014
thanks for the info.  will i be able to upgrade the firmware in my unit when the new version is released? or am i stuck with the bug?
This reply was originally posted by Angela on APC forums on 1/10/2014
I have confirmed this is a cosmetic only firmware bug that will be addressed next month in new units. If you see 101% and charging, it does indicate the UPS is really at 100% and fully charged.
This unit is not technically firmware upgradable for this UPS by a user but when the firmware is available, we can discuss options if you don't want to live with this.
daaan_apc
i would like to discuss those options.
Well I guess I meant more when it is confirmed there is a fix available since I can't do anything right this second unfortunately. I was told next month this would be in production so when it is, I can circle back with you. Feel free to post for an update if you don't hear from me.
This reply was originally posted by Angela on APC forums on 12/19/2014
Hello - FYI - this issue is resolved in BE750G firmware W4 (where you had firmware W3).
nigeltufnelny_apc
This was originally posted on APC forums on 11/20/2015
Hello, I just bought an ES-750 and am also seeing the 101% problem.  I have W3.  Where can I get W4?  Thanks.
