84729members
354148posts
powerchute software which supports serial port?
ws_is_apc
1255
This was originally posted on APC forums on 10/4/2007
Does anyone know where can I get the powerchute software which supports serial?
Re: powerchute software which supports serial port?
This reply was originally posted by Pino on APC forums on 10/22/2008
I have the same question. Where can I find a copy of the old Powerchute software that supports serial ports. My models are the:
Back-ups Pro 1000 (Model BP1000)
Back-ups 650 (Model BK650MC)
After talking to technical support, we determined that the Business Edition is not compatible with my units because they use simple signaling ports.
I'm about to give up, please help!
9 Replies 9
ws_is_apc
Grenade_apc
Lieutenant
Lieutenant
This was originally posted on APC forums on 10/5/2007
What model UPS do you have?
ws_is_apc
There are three different kinds.
1. APC Smart-UPS 2200
2. HP R5500 XR
3. Compaq R1500
Grenade_apc
Lieutenant
Lieutenant
This was originally posted on APC forums on 10/10/2007
Here is a link to the software/firmware download page at APC.
http://apcc.com/tools/download/
From here, the serial shutdown software is listed as Powerchute Business Edition. Version 7.0.5 is the latest revision and it would require a smart signaling APC serial cable, part # 940-0024.
KVM4Life_apc
Lieutenant
Lieutenant
This was originally posted on APC forums on 10/27/2008
Hello Pinofarinola,
The two models you listed, BP1000 and BK650MC, can be used with Powerchute Business Edition. The only difference is that they're Simple signaling devices, meaning Powerchute will only receive limited information, such as Online, On battery, or Low Battery. You won't see information such as run time, load, or voltage information. However Powerchute will still be able to gracefully shut your system down in the event of a prolonged power failure.
When installing Powerchute Business Edition, you will be prompted for UPS type. At this point you do not want to scan the COM ports for the UPS as this is another limitation of Simple signaling devices. You will want to specify the COM port and that the UPS is Back UPS or Simple Signaling Device. Once you've done this proceed with the rest of the installation.
If you run into any problems with this, please let me know.
JaxPlanet_apc
This was originally posted on APC forums on 9/28/2010
The version of PowerChute you use is dependent upon the model of UPS you use.
If you use a UPS that has a serial port with the correct version of PowerChute it will work.
A standard serial cable will not work. You must use a special serial cable with different pinouts for smart and simple signaling to work. You can buy one from any APC vendor.
Finally, APC has excellent phone support. Write down your serial number and give them a call. They will make sure you have the correct software and cables.
This reply was originally posted by tom on APC forums on 2/20/2019
What is the log in info. for the apc  ftp?
i need to get old powerchute plus for w95/98 so i can use for the serial port; newer softwares  don't support rs232 port
This reply was originally posted by Bill on APC forums on 2/21/2019
PowerChute Plus is no longer supported and has been removed from the FTP site. If you would like a copy hopefully one of the other forum member will make it available.
