  • Get started
Brand Logo
  • Get started
  • Community Home
    • By Topic
    • By Topic
      EcoStruxure Building
      • Field Devices Forum
      EcoStruxure Power & Grid
      • Gateways and Energy Servers
      EcoStruxure IT
      • EcoStruxure IT forum
      • EcoStruxure IT™ Advisor CFD
      Remote Operations
      • Remote Operations Forum
      Industrial Automation
      • AVEVA Plant SCADA Forum
      • CPG Expert Forum DACH
      • Machine Automation Forum
      • Modicon PAC Forum
      • PLC Club Indonesia
      Schneider Electric Wiser
      Power Distribution IEC
      • Specifiers Club ZA Forum
      • Електропроектанти България
      Power Distribution NEMA
      Power Distribution Software
      • LayoutFAST User Group Forum
      Light and Room Control
      • SpaceLogic C-Bus Forum
      Solutions for your Business
      Support
    • Geo SCADA Knowledge Base
    • Digital E-books
    • Success Stories Corner
    • All Events
    • Innovation Talks
    • Innovation Summit
    • Let's Exchange Series
    • Partner Success
    • Process Automation Talks
    • Technology Partners
    • EcoStruxure Building
      Remote Operations
    • By Topic
    • By Topic
      • Backstage Access Resources
      EcoStruxure IT
      Remote Operations
      • Remote Operations Blog
      • Industrie du Futur France
      • Industry 4.0 Blog
      • NEMA Power Foundations Blog
      • KNX Blog
      • Digital E-books
  • companyImpact
The old "UPS: The local network management interface-to-UPS communication not established." error and more
  • Communities
  • Re: The old "UPS: The local network management interface-to-UPS communication not established." error and more
  • Subscribe to RSS Feed
5026
195
Sisko Erasmus_apc
111
TheNotoriousKMP_apc
Sisko TheNotoriousKMP_apc
108
Posted: ‎2021-07-01 04:43 AM
392
This question was originally posted by Evandro on APC forums on 11/28/2013
I have an SUA3000RMXL3U-BR (identical to the other model, except for the standard of the output outlets, brazilian-defined).  It's brand new, with 4 months of use.
Recently I installed powerchute (newest version) and connected supplied usb cable. Worked fine. Detected and installed device driver automatically (windows 2008 enterprise server R2), and when I installed powerchute bussiness 3 components, (agent, server, console), it detected correctly my UPS and worked very well.
Suddenly, with no explanation, it lost the communication with the UPS. When I removed and plugged again the usb cable, the infamous message "
One of the USB devices attached to your computer has malfunctioned, and Windows does not recognize it
Tried everything, no success. So I started trying use the AP9630 wich is attached at the rear of the UPS. I update it's firmware, put an ip on it, accessed it fine via web. BUT EVEN NMC2 could communicate with the ups, generating in the logs the message describe in the title of this topic.
So, later, on the server, the message of sucessful recognition of the UPS apperead again, but the powerchute agent (I removed and reinstalled again) could'nt find the UPS as it did before.
Long story short : It appears all communicating capabilites of the UPS has vanished, since either via USB cable using the connector at the rear of the UPS or via NMC2 card, communcation with UPS not happens.
What do you need from me to start troubleshoting my problem ? I tried several solutions for similar problems here, but as far I could see, many people had many particular problems, so despite the fact the problem is a common issue, the solution can vary.
Thank you in advance,
Evandro
  • ap9630
  • communication
  • network_management_card
  • nmc2_communication
  • powerchute_lost_communication
  • ups_communication
  • ups_lost_communication_nmc2
This reply was originally posted by Evandro on APC forums on 11/29/2013
Guys and girls from tech support from APC, don't bother with my question.
Later I saw other KB here and found the solution.
You can't use BOTH network management AND usb management at same time. Either you disconnect the cable from you UPS NMC, or the USB cable (or serial) from the UPS.
Not both.
After disconnect my usb cable, the communication between NMC2 (ap9630) and the UPS changed to UP and online after an NMC2 reboot.
Thank you,
Evandro
Reply 1
Not both.
Thank you,
Evandro
Additional options
Already have an account?Login
