  • Get started
Brand Logo
  • Get started
  • Community Home
    • By Topic
    • By Topic
      EcoStruxure Building
      • Field Devices Forum
      EcoStruxure Power & Grid
      • Gateways and Energy Servers
      • Protection & Control
      EcoStruxure IT
      • EcoStruxure IT forum
      • EcoStruxure IT™ Advisor CFD
      Remote Operations
      • Remote Operations Forum
      Industrial Automation
      • AVEVA Plant SCADA Forum
      • CPG Expert Forum DACH
      • Machine Automation Forum
      • Modicon PAC Forum
      • PLC Club Indonesia
      Schneider Electric Wiser
      Power Distribution IEC
      • Specifiers Club ZA Forum
      • Електропроектанти България
      Power Distribution NEMA
      Power Distribution Software
      • LayoutFAST User Group Forum
      Light and Room Control
      • SpaceLogic C-Bus Forum
      Solutions for your Business
      Support
    • Geo SCADA Knowledge Base
    • Digital E-books
    • Success Stories Corner
    • All Events
    • Innovation Talks
    • Innovation Summit
    • Let's Exchange Series
    • Partner Success
    • Process Automation Talks
    • Technology Partners
    • EcoStruxure Building
      Remote Operations
    • By Topic
    • By Topic
      • Backstage Access Resources
      EcoStruxure IT
      Remote Operations
      • Remote Operations Blog
      • Industrie du Futur France
      • Industry 4.0 Blog
      • NEMA Power Foundations Blog
      • KNX Blog
      • Digital E-books
  • companyImpact
SmartUPS C1500 error p.06
  • Communities
  • Re: SmartUPS C1500 error p.06
  • Subscribe to RSS Feed
5027
195
Sisko Erasmus_apc
111
TheNotoriousKMP_apc
Sisko TheNotoriousKMP_apc
108
mattjennings
Crewman mattjennings
Posted: ‎2022-01-09 04:42 AM
4
7273
So a 7(ish) year old Smart UPS C 1500 has suddenly thrown an error p.06 on the LCD screen.  I've put in a new battery and still getting the same error. I can't seem to find anything anywhere what the error relates to. Once the error is thrown it cuts off battery supply to the outlets. Passes a self test OK from cold start. Battery seems to charge ok, and will run happily when not plugged into the mains.
Any ideas as the what the fault is, and is it repairable cost effectively?
  • error p.06
TonKei
Lieutenant TonKei Lieutenant
Lieutenant
Posted: ‎2022-01-13 01:05 AM
7219
Hi Matt
I believe the P.06 fault is related to the AVR relay.
Basically, this means that the relay that does the switching when the unit is either boosting or trimming the power, is possibly faulty.
Next step should be to unplug the equipment connected to the UPS, and then proceed to unplug the incoming power and then the battery.
After a minute or two, reconnect the battery and the input power and turn on the unit.
If the error persists, the relay is broken.
BR
/Tonny
Replies 4
TonKei
Lieutenant
7220
Hi Matt
BR
/Tonny
mattjennings
Posted: ‎2022-01-13 05:50 AM
In response to TonKei
7215
Thanks for the info Tonny, i'll investigate further. I've tried the unplugging and trying again method, so i guess the relay is shot. I've just come across a youtube link that supposedly shows how to replace the relay.. https://www.youtube.com/watch?v=AW2ZKtzr0rc
I'll post back with any success/fail stories.
Best wishes,
Matt
TonKei
Lieutenant
Posted: ‎2022-01-13 06:02 AM . Last Modified: ‎2022-01-13 06:02 AM
In response to mattjennings
Hi Matt
Best of luck!
Just note that unplugging the battery, as well as the input power, is required to do a complete reboot of the UPS.
The clue here is to let the unit go though the self test it is performing at startup, just to be sure the alarm is valid.
BR
/Tonny
Stebone
Stebone
Posted: ‎2023-01-27 07:28 PM
I just bought a Smart UPS SMT1500c (2-days old) and received the P.06 error.  Can't be a bad AVR relay already.  Not happy!!
Additional options
